| PC Based Computer music servers, crossovers, and equalization |
I just bought a USB to Coax converter to connect my lap top to my DAC. Based on some feedback, I would like to use a regulated power supply to feed the converter instead of the USB BUS. How do I modify the USB cable to achieve this? IS there a color code for the +5V line? Is 500mA a sufficient supply current max?
Thanks Salsero |
#2 |
#3 |
Sometimes a square peg fits a round hole just fine
the pinout is not enough for this, as the host will try to 'ping' the device on the 5V line to check it is there. without the 5V line connected no audio will be sent to the device.
there are ways around this though Analogue devices makes a chip for isolating the USB power supply the ADuM4160 which can be used in circuits like this and only this will allow you to add your own higher quality power supply. before this device I made a couple of cables simply splicing power into the +/-5V supply lines with a DC plug on them, but it doesnt work, the device isnt recognized (much to my dismay) but the PCb linked is quite cheap as is the fully built unit if you wish an out of the box solution. Last edited by qusp; 9th January 2010 at 02:13 PM. |
#4 |
Thanks, very useful feedback. Definitely more complicated than splicing cables.
Cheers Salsero |
#5 |
No problem, yeah it is unfortunately. the 'ping' is made when the host wants to negotiate the speed, full speed, high speed, USB 2.0 etc. devices that have their own power supply for the usb receiver/dac dont always need it and the power wires can be omitted in this case. I have never struck one though, because of the reasons I mention above. even in devices that have their own power often still pull the power for the usb codec/receiver/i2s from the 5v line
#6 |
If I can't use an external supply the easy way (i.e. splicing cables, etc...), would a cap or other circuitry help clean the PC power source?
Cheers, Salsero |
#7 | |
But try the splicing cable method first if you can, it worked for my PCM2702 DAC. |
#8 |
thats because that chip is really only a USB receiver that has a rudimentary dac function, but sure give it a try its a cheap solution
#9 |
The same must then hold for the PCM2902 - the chip used in the USB to SPDIF converter I am using. Please confirm.
Thanks Salsero |
#10 |
I have made a simple adapter to supply more current to USB devices by simply rewiring the output power connection to a regulated 5v wall wart. Everything I have used it on work just fine.
However, you're not going to get any isolation since the grounds will still need to be connected for data. Use an optical connection for that. On the digital side, reducing noise is not going to do anything if it is operating properly in the first place. USB to S/PDIF adapters have built in voltage regulators anyways.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
| E-MU 0404 USB Modification? | lumanauw | Digital Line Level | 67 | 7th February 2011 09:50 AM |
| usb modification for survelliance. | sagarverma | Digital Source | 8 | 5th January 2006 09:39 AM |
| i2s bus vs. i2c bus | Doovieman | Digital Source | 8 | 13th October 2005 08:06 PM |
| usb flash drive modification | Hayden | Parts | 0 | 19th August 2004 06:56 AM |
| USB DAC (in the cable!?) | rjm | Digital Source | 5 | 13th May 2004 09:19 AM |
| Page generated in 0.10062 seconds (80.12% PHP - 19.88% MySQL) with 10 queries |
