Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 1st November 2010, 11:04 AM   #61
theresa is offline theresa  United States
Default a good amp is a good amp
Originally Posted by lazycatken View Post
Seems good idea to make cost lower. How's quality?
In HiFi point of view, most home theater amplifier are not good enough for music... Any candidate?
As long as they measure the same in complete measurements they will sound the same. If one is using an amp with 1% distortion such as PA and other amps meant for commercial use are going to sound bad. Receivers these days deceive with their specs, so to get the "rated power" you nearly have to use separates intended for home use. Most people never notice but they are being lied to with power specs.
Old 1st November 2010, 01:26 PM   #62
macboy is offline macboy  Canada
I think receiver power ratings are not "lies" but are deceptive. If it says 100 W per channel you can get 100 W.... from one channel at a time.
Old 1st November 2010, 02:59 PM   #63
I found several programs that allow you to use a multi-channel sound "card" as a digital crossover. I really don't think the onboard realtek is that good so I bought miniDSPs which don't require any processing power after setting them up, unlike using a soundcard, from the computer and they use higher def circuitry than most sound cards. Active crossovers are incredibly complex to wire up, at least for me. I blew one expensive tweeter already by hooking the wrong cable to it. I don't know if there is any improvement in sound quality with digital active crossovers but am largely attracted to it because it is a complex problem for me to work on in my head and using measurements. The miniDSPs now interfaces and imports measurements from Room Eq Wizard, a freeware program which makes adjustments much easier. It all becomes expensive with more amps, more cables, measurement mic etc.
Old 6th November 2010, 09:46 PM   #64
Purposeful deception=lying
Old 25th April 2012, 08:14 PM   #65
How are the Mini DSP's working for you. I'm intersted in this approach.
Free Digital Room Correction And PC based Xover kipman725 Multi-Way 3 7th August 2009 12:13 PM
Progress report - digital crossover as a DAC - digital all the way to the amps Ken L Multi-Way 0 26th November 2006 11:42 PM
DTS and Dolby Digital ntornkvi Digital Source 11 14th September 2004 06:17 AM
Dolby Digital..... bimbla Digital Source 3 31st March 2004 09:02 AM
PC Based Digital source with DEQ/DCX functionality? ultrachrome Digital Source 12 27th October 2003 06:26 AM
Page generated in 0.09937 seconds (77.14% PHP - 22.86% MySQL) with 10 queries
