diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   PC Based (http://www.diyaudio.com/forums/pc-based/)
-   -   Please! (http://www.diyaudio.com/forums/pc-based/154512-please.html)
Lumba Ogir 5th November 2009 10:33 PM
Please!
Hi everyone,
how to simulate a fan (to fool the computer) on a 3 pin system fan connector (ground-+12V-sensor)?
Thanks.
MJL21193 5th November 2009 10:49 PM
Measure the DC resistance on the gnd/12V leads from the fan and match it with a fixed resistance maybe? Worth a try.
Gary P 6th November 2009 03:02 AM
Are you trying to get the computer to not give you the "CPU fan fail" warning at boot?
Look in the bios settings for a setting about CPU fan check and disable if possible.
dangus 6th November 2009 05:52 AM
Bios settings, or use the speed signal from another fan in the system. Or use an oscillator to fake a signal.
Lumba Ogir 6th November 2009 07:55 AM
Hi guys,
Exactly.
That´s not an option in this custom-made BIOS/MoBo.
I once solved the problem with a resistor between sensor and ground. It does not seem to work this time.
stinius 6th November 2009 09:09 AM
Hi
You will need a “Pseudo Fan” to fool the controller. The controller needs to see a square wave to “think” that the fan is running.
See July/August issue of Elektor page 17.
Link:
Cheers
Lumba Ogir 6th November 2009 09:21 AM
dangus and stinius,
interconnecting the sensors of system fan and processor fan (which is active) would be a simple enough solution.
wwenze 6th November 2009 11:45 AM
If you have an extra fan and your motherboard can use speedfan, just connect the extra fan and set speedfan to auto disable to fan after booting into Windows.
That's what I do anyway. My mainboard is also OEM with no option to disable CPU fan warning. And I have a Scythe Ninja to run fanless an undervolted A64 with.
Lumba Ogir 7th November 2009 09:06 PM
no success yet, fan speed control is very problematic these days...
Fan Speed Control is Cool! - Maxim
http://pdfserv.maxim-ic.com/en/an/AN1784.pdf
stinius 7th November 2009 09:42 PM
Originally Posted by Lumba Ogir (http://www.diyaudio.com/forums/pc-based/154512-please-post1973425.html#post1973425)
no success yet
Hi
What have you tried so far without success?
stinius
Resources saved on this page: MySQL 18.75%
