| PC Based Computer music servers, crossovers, and equalization |
#11 |
#12 |
The hardware on my old rooter was nothing like this stuff, this even has HDMI out!
Texas Instruments OMAP35xx Dual-Issue, ARM Cortex-A8 @ 600MHz ( Does this mean duel core?) 64x+DSP @ 430MHz Peak MMACS 3440 64-Ch EDMA,32-Bit Channel SDMA 256 MB DDR 512 MB NAND SD/MMC 10/100 Mbps RJ45 Ethernet jack 1 x USB 2.0 HS USB host port 1 x debug serial port 1 x IrDA receiver (over serial port) Bluetooth module (optional) HDMI display output at connector Display signals also at 0.100" headers Audio line-out at RCA connectors 12 x 32-Bit GP Timers 2 x 32-Bit WD Display Graphics accelerator 5VDC input voltage at power jack or PoE module |
#13 |
@nmiljac
i would like to know if you had to write your own (audio) driver for your system based on ARM9 + I2S + DAC or it is possible to use alsa driver, i saw on alsa sources many drivers for SOC based on ARM also for ATMEL, OMAP and others: Linux/sound/soc/ for example on this: Linux/sound/soc/atmel/atmel_ssc_dai.c i see the SSC port on ATMEL ARM can be used as I2S both master and slave ciao andrea |
#14 |
I actually wrote the ALSA driver for my custom DAC.
#15 |
Hi......First Post!
I need a board to feed a DAC via USB and am considering the ALIX (because of the recommendation on this thread) or a fanless atom mobo. I am wondering if anyone has used the ALIX board with a wifi card? Has anyone used a fanless atom solution with a wifi card? Would the only major difference between the ALIX and Atom be power consumption? I like the idea of hacking a router (seems like the cheapest option), but I don't think my skills are up to it. Thanks Matt |
#16 | |
Also, you won't easily find an inexpensive fanless Atom board that is stripped down and/or headless like the Alix is. There are some SBC Atom's on the market, but they're very expensive in single quantities. Sokeris should be coming out with a fanless Atom board later this March, but it won't nbe cheap. And, you don't need the power an Atom CPU to feed unmolested data to a USB DAC, even at 24bit/192Khz. |
#17 |
@ nyc_paramedic
Thanx for your quick response. I think I will go with an Alix board. Can you elaborate on the problem with using WiFi with Alix? Did you mean wifi in this general application is problematic? I will be using mpd on the Alix (probably using Voyage Linux) via NFS to my Arch server. I could get an Ethernet to where my stereo sits but it will not be "clean". However, I do not want to trade off wifi for quality. |
#18 | |
From what I've read, none of the high end music server manufactures, (Linn?) recommend Wi-Fi streaming when you want the best fidelity. Stay with wired ethernet. Also, it's not difficult at all to drill small holes between walls to route Cat5/6. My first time doing it was very easy. Borrow a staple gun to keep the cable nice an tidy against the trim. |
#19 |
Umm:
Fanless Atom Board requires ATX power supply (which still can be fanless using a variety of options such as the picoPSU which integrates an ATX psu, HD plug, etc. into a small factor and requires just a wall wart to supply initial power) Another Fanless option which uses a self contained power supply (no fans) Last edited by PedroDaGr8; 30th January 2011 at 06:09 AM. |
#20 |
Consider also the Seagate Dockstar boards. They can be had on sale for < $50, are easily hackable (ie. no hardware mods required), have a bunch of USB ports, and are more than powerful enough for a remote media player. I don't see a reason to pay 4 times as much for a more power-hungry, larger x86 solution (though the ALIX boards do make fantastic pfSense routers...); don't forget to factor in the additional cost for a CF card, power supply and case. Once you've got Debian installed (which is easy), there's not going be much difference. Install Debian to the internal flash memory, add a USB sound card (and maybe an IR receiver) and you're done.
It's a popular 'hacking' platform, so there's a decent community around it. Expand your NAS is a good resource for these. Debian on the Seagate Dockstar - David Darts Wiki is a nice tutorial Haven't actually built one just yet, but it's on the list so I don't have to use my HTPC when I just want to listen to music. I think WiFi would work fine; audio is crazy low bandwidth, unless you've got a really crappy dongle or really terrible signal conditions it'll work fine. You might get more EMI etc, but that hasn't really been a problem for me.
http://audio.gotroot.ca/ Last edited by error401; 1st February 2011 at 04:55 AM. |
| Hitachi Servo/RF-Amp HA12158NT ("HA 12158 NT", HA12158, "HA 12158NT") from Linn Karik | tiefbassuebertr | Digital Source | 6 | 27th June 2011 02:14 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 07:42 PM |
| Linux XO/DRC Fanless PC w. Lynxtwo | jon_denmark | Digital Source | 6 | 20th July 2007 07:54 AM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 07:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 09:42 AM |
| Page generated in 8.33752 seconds (0.79% PHP - 99.21% MySQL) with 10 queries |
