| PC Based Computer music servers, crossovers, and equalization |
#31 | |
Partitioned convolution allows you to get the same result with less latency by partitioning up the large block, processing the sub-blocks individually and adding the results up in a specific way. Using smaller partitions produces less latency, but requires more CPU power. I think by `high throughput', the author is likely to be talking about very very long filters (say, 32k taps). With a filter that long you'd be limited by most hardware in terms of how many partitions could be handled. 32k taps far longer than you'd need for a conventional audio filter, but I don't know about room correction. It's less than a second's worth of impulse response, so longer still might be needed. In the end, I think you're right - you'll just need to try it on your computer with your filters, and see what happens. I don't see why there'd be a limit on the number of partitions with your soundcard - I thought the two were entirely independent. But yeah, do check the manual
Wingfeather |
#32 |
Sound card and associated hardware
I purchased a superseded RME9636 sound card on EBay for use in the system. It has two SPDIF connectors and four ADAT optical connectors providing 16 input channels and 16 output channels (simultaneous) at 48kHz sampling frequency. But no on-board convertors. I also purchased a Behringer ADA8000, providing 8 DACs and 8 ADCs. The Behringer is set as the clock master, with a 48kHz sampling frequency. It produces a 24 bit data stream for each channel. PC hardware I initially bought a super small PC box to use for running BruteFIR. It looked like the real deal: small, fast, neat and quiet, and with a full sized PCI slot. The specs were: Processor: Via Low Power C3/Eden Processor at 800MhzBut, I couldn’t get Linux to install, in any of the flavours of Fedora, Ubuntu or SPLinux. So, I ditched that hardware and went for a second-hand small form factor IBM PC, spec’d as follows: Make/Model: IBM/ThinkCentre M51 8106-D1MThe BIOS has a “quiet” mode for the fan which is actually really quiet, very useful for making sure there is no intrusion while listening. Ironically the IBM is faster, has more memory, a hard drive (absent from the other box), and was cheaper than the first box. Oh well, such is the life of the filter DIYer. Fedora installed without a hitch in under 30 minutes. The RME card also installed without a problem and was recognised by ALSA. No GUI interface for the card (too old) so its command line prompts only. I also bought a USB wireless receiver and I can now remotely control the PC from my laptop, using ssh and vncserver under Fedora. The ALSA “amixer contents” command shows the following: Code:
numid=5,iface=MIXER,name='IEC958 Input Connector' ; type=ENUMERATED,access=rw------,values=1,items=3 ; Item #0 'ADAT1' ; Item #1 'Coaxial' ; Item #2 'Internal' : values=1 numid=6,iface=MIXER,name='IEC958 Output also on ADAT1' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=10,iface=MIXER,name='IEC958 Sample Rate' ; type=INTEGER,access=r-------,values=1,min=0,max=96000,step=0 : values=-1 numid=15,iface=MIXER,name='ADAT1 Input Source' ; type=ENUMERATED,access=rw------,values=1,items=2 ; Item #0 'ADAT1' ; Item #1 'Internal' : values=0 numid=11,iface=MIXER,name='ADAT1 Sync Check' ; type=ENUMERATED,access=r-------,values=1,items=4 ; Item #0 'No Lock' ; Item #1 'Lock' ; Item #2 'No Lock Sync' ; Item #3 'Lock Sync' : values=0 numid=12,iface=MIXER,name='ADAT2 Sync Check' ; type=ENUMERATED,access=r-------,values=1,items=4 ; Item #0 'No Lock' ; Item #1 'Lock' ; Item #2 'No Lock Sync' ; Item #3 'Lock Sync' : values=0 numid=9,iface=MIXER,name='Channels Thru' ; type=BOOLEAN,access=rw------,values=18 : values=off,off,off,off,off,off,off,off,off,off,off,off,off,off,off,off,off,off numid=14,iface=MIXER,name='Passthru' ; type=BOOLEAN,access=rw------,values=1 : values=off numid=8,iface=MIXER,name='Preferred Sync Source' ; type=ENUMERATED,access=rw------,values=1,items=3 ; Item #0 'IEC958 In' ; Item #1 'ADAT1 In' ; Item #2 'ADAT2 In' : values=1 numid=7,iface=MIXER,name='Sync Mode' ; type=ENUMERATED,access=rw------,values=1,items=3 ; Item #0 'AutoSync' ; Item #1 'Master' ; Item #2 'Word Clock' : values=0 numid=13,iface=MIXER,name='Timecode Valid' ; type=BOOLEAN,access=r-------,values=1 : values=off numid=3,iface=PCM,name='IEC958 Playback Con Mask' ; type=IEC958,access=r-------,values=1 : values=[AES0=0x3b AES1=0x00 AES2=0x00 AES3=0x00] numid=1,iface=PCM,name='IEC958 Playback Default' ; type=IEC958,access=rw------,values=1 : values=[AES0=0x00 AES1=0x00 AES2=0x00 AES3=0x00] numid=4,iface=PCM,name='IEC958 Playback Pro Mask' ; type=IEC958,access=r-------,values=1 : values=[AES0=0x1f AES1=0x00 AES2=0x00 AES3=0x00] BruteFIR setup The BruteFIR configuration file looks like this: Code:
# Version 1
# Squeeze box output to filter PC then to CX310 crossover. From X'over to front end system, sub to A500 amp and Thor.
# Decoder FR and FL output to same chain as SQB. Surround channels to DSPA1.
# Decoder centre mixed to FR and FL.
# Sub from crossover delayed but not otherwise filtered.
# No LFE signal from decoder.
# ADA8000 physical connections
# IN Channel OUT Channel
# 1 - SQB left 1 - Spkr Front Left
# 2 - SQB right 2 - Spkr Front Right
# 3 - Decoder Front L 3 - Spkr Surr Left
# 4 - Decoder Front R 4 - Spkr Surr Right
# 5 - Decoder centre 5 - Spkr Side Left - future use
# 6 - Decoder Surr L 6 - Spkr Side Right - future use
# 7 - Decoder Surr R 7 - Spkr Sub
# 8 - crossover_sub 8 - not used
## General Settings that overide defaults in .brutefir_defaults ##
float_bits: 32; # internal floating point precision
sampling_rate: 48000; # sampling rate in Hz of audio interfaces
filter_length: 4096; # length of filters
overflow_warnings: true; # echo warnings to stderr if overflow occurs
show_progress: true; # echo filtering progress to stderr
#show_progress: false; # echo filtering progress to stderr
max_dither_table_size: 0; # maximum size in bytes of precalculated dither
allow_poll_mode: false; # allow use of input poll mode
modules_path: "."; # extra path where to find BruteFIR modules
monitor_rate: false; # monitor sample rate
powersave: -70; # pause filtering when input is below 70 db from 0db reference
#powersave: false; # pause filtering when input is null samples
lock_memory: true; # try to lock memory if realtime prio is set
sdf_length: -1; # subsample filter half length in samples
convolver_config: "~/.brutefir_convolver"; # location of convolver config file
########################################## COEFFS ##
coeff "DRC_erb_44100_wav"
filename: "/home/bryan/drc filters/erb-44.1.wav";
format: "S16_LE"; # file format
blocks: -1; # how long in blocks
skip: 0; # how many bytes to skip
shared_mem: false; # allocate in shared memory
########################################### INPUTS ##
input "squeeze_left", "squeeze_right", "decoder_front_left", "decoder_front_right", "decoder_centre", "decoder_sur_left", "decoder_sur_right", "crossover_sub"
device: "alsa" { param: "hw:R15"; } ; # module and parameters to output audio
sample: "S24_4LE"; # sample format
channels: 18/0,1,2,3,4,5,6,7; # number of open channels / which to use
delay: 0,0,0,0,0,0,0,0; # delay in samples for each channel
maxdelay: -1; # max delay for variable delays
mute: false,false; # mute active on startup for each channel
########################################### OUTPUTS ##
output "spkr_front_left", "spkr_front_right", "spkr_sur_left", "spkr_sur_right", "spkr_side_left", "spkr_side_right", "spkr_sub"
channels: 18/0,1,2,3,4,5,6; # number of open channels / which to use
delay: 0,0,0,0,0,0,210; # delay in samples for each channel. For sub, need to delay 1.5 metres = 4.373 milliseconds. @ 48KHz sampling = 210 samples.
# @ 44100Hz sampling = 193 samples.
dither: false; # apply dither
############################################# FILTERS ##
## INTERMEDIATE FILTERS ##
filter "squeeze_left_passthru"
from_inputs: "squeeze_left";
to_filters: "front_left_filter";
coeff: -1; # no filtering, just pass through
#coeff: "DRC_erb_44100_wav"; # 16 bit wave file for filter
process: 0; # process index to run in (-1 means auto)
delay: 0; # predelay, in blocks
crossfade: false; # crossfade when coefficient is changed
filter "squeeze_right_passthru"
from_inputs: "squeeze_right";
to_filters: "front_right_filter";
filter "decoder_front_left_mix"
from_inputs: "decoder_front_left", "decoder_centre"/3.0;
filter "decoder_front_right_mix"
from_inputs: "decoder_front_right", "decoder_centre"/3.0;
## FINAL FILTERS TO OUTPUTS ##
filter "front_left_filter"
from_filters: "decoder_front_left_mix", "squeeze_left_passthru";
to_outputs: "spkr_front_left";
#coeff: -1; # no filtering, just pass through
filter "front_right_filter"
from_filters: "decoder_front_right_mix", "squeeze_right_passthru";
to_outputs: "spkr_front_right";
filter "sur_left_passthru"
from_inputs: "decoder_sur_left" ;
to_outputs: "spkr_sur_left";
filter "sur_right_passthru"
from_inputs: "decoder_sur_right" ;
to_outputs: "spkr_sur_right";
filter "side_left_passthru"
to_outputs: "spkr_side_left";
filter "side_right_passthru"
to_outputs: "spkr_side_right";
filter "sub_passthru"
from_inputs: "crossover_sub" ;
to_outputs: "spkr_sub";
At present its using just one .wav file as a filter, created under DRC then put into a .wav format by the Inguz software (for use with the squeezebox server). The main item of note in the configuration file is the filter length parameter. It only works for a value of 4096. Anything larger and the output signal has strange echo artefacts - maybe its because the filter is a 16 bit wav file. I won’t know for sure until I create proper floating point .pcm coefficient files from DRC. Also a weird situation: the PC now has two sound cards: the built-in Intel one, and the RME. Sometimes on start-up the RME would be listed as card zero, sometimes as card 1. I originally had an ALSA call in the BruteFIR file to “hw:1,0” (assuming the RME card would always be 1 and the Intel card zero) but of course that would fall over if the RME was card zero. So I changed it to read “hw:R15” which is the other way ALSA knows about the card (got that info from /proc/asound/cards). So now its independent from how ALSA loads the cards at start-up. One neat function is that BruteFIR can delay input or output channels in single sample increments. So I can delay the output to the Thor sub-woofer by 210 samples (at 48kHz sampling), which is equivalent to delaying the signal by 1.5 metres. It also means I can sell my digital delay unit which has now become redundant, so that’s one less box to power. Physical setup The PC is located in the dining room next to the lounge room. So I need to run toslink optical cable from the main collection of equipment to the PC and then back again to the amps and speakers. So I’ve ordered 2 x 10 metres of toslink cable: the analogue inputs (CD, PVR etc) go into the ADA8000 located in the same cabinet, then the data stream goes via optical cable to the PC, then back to the ADA8000 for conversion to analogue and routing to the amps and speakers. Ten metres is apparently the limit for toslink cable, so we’ll just have to see how that goes. More as things progress. As always questions welcome. Last edited by boconnor; 21st December 2009 at 11:06 AM. |
#33 |
So, the 10m Toslink cable arrived and has been installed. No problems with 10m length that I can detect. The PC running the filters can be placed in an adjacent room to the listening (lounge) room. Even though the PC is pretty quiet, the distance means there is no noise at all from the PC to the listening position.
Next update: dealing with latency problems with the audio stream from video playback. |
#34 |
Previous posts have discussed the problem of latency caused by FIR filters. After some experimenting I have found that its not possible (in my setup) to get video images and the video audio in sync with each other, if the audio is processed through a FIR room correction filter with BruteFIR.
I have tried the following to reduce the latency delay:
So, the audio from videos is processed thus:
The front left and right output from the PC is then sent via SPDIF to a Behringer DCX2496 for 3 way active crossover processing and onto the front speaker amps. The delayed sub woofer signal is sent back to the ADA8000 via the Toslink cable and after conversion to analogue fed to a Behringer A500 amp that drives the subwoofer. By avoiding any long FIR calculations the audio from video is completely in sync with the video image. Sound quality is still excellent. Over time I will experiment with getting the audio from video into the filter chain. Current thoughts are to use VLC under Linux as the video player. It has great options for user defined delays to video streams. What I need to do is get the multi-channel digital audio stream out of VLC and into BruteFIR. Probably by using the JACK server, but I haven’t really explored this yet. Next update: Finally, concert hall impulses and rear channel reverb! |
#35 |
If your audio setup has a constant delay, playing video from the same PC should allow any controllable delays in the video stream to synchronize with the sound - see e.g. the -delay option of mplayer.
#36 | |
As I said, the video stuff is on the radar, not just the highest priority at present (there are concert halls to simulate! |
#37 |
I have brutefir running roomcorrection in 5.1 system and doing 3-way crossovers for each speaker. No problem with latency. 50ms measured with PS3 Singstar mic-loop
. The way to do it
#38 | |
How did you get such a short filter? I use Denis Sbragion's DRC program. With the default settings it produced a 32,000 tap filter. It would be appreciated if you expand on your room correction procedure / DRC filter settings. |
#39 |
drc manual says..
6.11.8 PSOutWindow Final window after post filtering. This is also the length of the generated correction filter. Usual values are between 8192 and 65536. Filter with 65536 taps gives about 0.5 Hz resolution at 44.1 KHz sample rate, 16384 is usually enough for most situation and 8192 gives somewhat good results with much less computing needs during real time convolution. May be that correction in bass tones is slightly decreased if the filter length is 4096. |
#40 | |
I must admit I haven't done so - I just implicitly trusted Sbragion's default values. Your post has piqued my interest in trying out some shorter filters. As to the benefits of filter length, my understanding is that the longer the filter the better the filter is at controlling low frequency variations (as you noted). I really like how controlled the bass is in my listening room now - sort of a seamless transition from mid frequencies down to the sub 40Hz range. |
| Digital Room Correction and Foobar2000 Convolve | mr.duck | Digital Line Level | 1 | 23rd June 2009 05:49 PM |
| DIY DSP for Digital Room Correction | OzOnE_2k3 | Digital Source | 114 | 17th June 2008 09:25 PM |
| Audyssey MultEQ XT Digital Room Correction | wigginjs | Multi-Way | 37 | 24th February 2008 07:10 PM |
| I need help with digital Room-correction | Radian | Multi-Way | 1 | 7th February 2007 08:10 PM |
| Page generated in 0.20313 seconds (86.59% PHP - 13.41% MySQL) with 11 queries |
