| PC Based Computer music servers, crossovers, and equalization |
#21 | ||
And a very informative and helpful one! Thanks for posting it, its clarified a number of things for me.
So, I guess I’m likely to need to fix-up the latency difference between the video and audio. Any recommendations on a value-for-money unit that can delay video? Quote:
#22 |
FYI,
Here is a pointer to two new commercial DSP room correction products. 'Dirac Live' on the AP20 & Dirac one
Best Regards, Carl Huff |
#23 | |
Wingfeather |
#24 | |
#25 |
Wingfeather,
Thanks a lot for a very informative post. boconnor, Good luck with your setup, I hope the latency does not get to be too much. |
#26 |
I’ve been thinking about the options to deal with the audio latency issues highlighted in previous posts on this thread. I see three options at present:
#27 | |
Capturing video signal on a pc means that you will be taking it from analog to digital and then back again? That might mean exchanging one devil with another, Audio quality will be exchanged for video quality. It would be good if you could take Video in digital domain into a PC, delay it and send it back out in digital domain. Indeed. |
#28 |
I have thought about the best way forward. Because I like to fully utilise existing equipment, and get value for money for my expenditure, I have decided to keep my existing video gear, and not to buy a video delay unit. So the current plan is:
FIR filter all audio (both music and from the home cinema). Check sync between video image and audio. If there is a sync problem, then change the BruteFIR configuration file to not filter the home cinema audio except for the sub-woofer channel, which will always be filtered. On balance this seems reasonable given the quality of audio on DVDs.Any delay in the sub woofer channel is fine because I need to delay the sub woofer channel in any case, since it is too close to the listening position relative to the front speakers. I also need to deal with the sub 100Hz room modes. The trick here is to get the overall delay right, which combines the inherent delay of the filter with the delay required because of physical distance between speakers. So, if anyone has an easy method to determine the FIR filter delay through BruteFIR (I need a method that provides the actual millisecond number), please jump in. |
#29 |
Hmmm, there's the `manual' method:
- I believe that both BruteFIR's block latency and the sound card's latency should be choosable/reported to you. - If you have a filter file and some means to graph it (Excel, et all might work? MATLAB definitely does), then you can eyeball it for the first large peak. Just add all those up and I think you should get your answer. If it's in samples then of course just divide by sample rate to get a value in seconds. If you don't have the means to look at the filter file yourself then I'll be happy to do it - just send it over to me.
Wingfeather Last edited by Wingfeather; 6th November 2009 at 11:50 AM. |
#30 | |
![]() So I looked more closely at the BruteFIR documentation, which of course turns out to be a more useful thing to do than the cursory glance I gave some sections of the documentation when I first read them! It looks like changing a parameter called the ‘partition size’ can vary the latency (delay), although the latency does also depend on hardware performance of RAM and other factors. It also turns out that BruteFIR can produce benchmark statistics. A configuration file with a specified filter is provided where you can check actual latency results against a table in the documentation. Ominously, there is this in the documentation: “If you want to run BruteFIR to achieve high throughput, you should expect to have a delay of at least 100 ms …" Like most things I guess I will only really know by applying my own filters with my own hardware. Although for my soundcard there appears to be a restriction on the partition size that can be specified (RME Digi9632 - max 8 partitions? – need to check the manual on that ). So before actually doing some measurements I suspect the latency will be above the threshold that has been mentioned earlier that causes problems in syncing audio with the video images.Still, I’ve got some things to get right before we get to the point of doing actual measurements with filters. I’m having all sorts of problems getting Linux installed on the mini PC box I purchased. But that, as they say, is another story ... |
| Digital Room Correction and Foobar2000 Convolve | mr.duck | Digital Line Level | 1 | 23rd June 2009 05:49 PM |
| DIY DSP for Digital Room Correction | OzOnE_2k3 | Digital Source | 114 | 17th June 2008 09:25 PM |
| Audyssey MultEQ XT Digital Room Correction | wigginjs | Multi-Way | 37 | 24th February 2008 07:10 PM |
| I need help with digital Room-correction | Radian | Multi-Way | 1 | 7th February 2007 08:10 PM |
| Page generated in 0.14416 seconds (84.64% PHP - 15.36% MySQL) with 11 queries |
