| PC Based Computer music servers, crossovers, and equalization |
#61 | |
Banned
dbPoweramp does a much better job ripping quickly with a typical drive than EAC does though. But if you find a drive that does not cache data on audio ripping, as described here, one can get rips that average around 22x speed over the disc in secure mode with EAC. Most of the slowdown in EAC secure mode happens with the brute-force way in which it must flush the cache before comparing data from multiple reads. So for drives for which do not cache data when ripping audio, in most cases you'll get vastly improved ripping speed. For example, the Samsung SH-S223 series of drives do not cache. Another possibility, which I haven't tried because I don't have any drives that support it, is the EAC USEFUA command-line option. This makes use of the FUA command, originally implemented with Plextor drives but also used by some others, which is essentially a "fast cache flush" command. dbPoweramp supports this command as well. In theory this should speed up ripping too, but I don't have any data to know for sure. It's certainly something to look at. All in all, I'd say dbPoweramp is a bit better, but for the cheapskate who doesn't mind experimenting a bit, EAC is hard to beat. |
#62 |
I certainly agree with the past few posts. As good and free as EAC is, dBPoweramp is faster, easier and tags better. And if it has doubts about a rip, it tells you. It's the best I've seen.*
As said above, keep EAC around for the really messy CDs. I use it for that too. * I started ripping and playing back in the last century with MMJB. Moved onto BeOS as long as that lasted. (Still a great audio OS.) But the new windoze stuff is really so much better than it used to be. |
#63 |
MS Malware tool found TrojanClicker:Win32/Yabector.A from EAC on my system:
From that link: "In the wild, this program was observed installed by an installation for the audio application "Exact Audio Copy" (EAC) as a file named "eBayShortcuts.exe"." Encyclopedia entry: TrojanClicker:Win32/Yabector.gen - Learn more about malware - Microsoft Malware Protection Center Here people are stating that all you have to do is opt out of the ebay shortcuts option during the install process which I did. People there are stating that as long as you opt out you are fine, MS seems to claim that it is more severe - not sure which is correct. |
#64 | |
I have set up dBpa for Acurate rip and a maximum of 2 secure rips. Max frame re-reads to 5. That showed me the fastest way of ripping. If dBpa needs more than 2 re-reads or start re-reading frames it is better to skip those tracks and inspect your CD for debris and scratches. Better clean your CD’s then with a mild detergent and/or polish out the scratches with metal polish and a soft cloth. That way a was able to rip even “difficult” CD’s 100% error free (according to Accuraterip). It is always worth to inspect your CD’s before ripping. Even very small scratches/debrsis that is nearly invisible can cause read errors. The only thing dBpa has problems sometimes and need I to fallback to EAC is with hidden first tracks. But these are rare. Last edited by Pjotr; 14th December 2009 at 01:34 PM. |
#65 |
I have found that EAC is the best so far it may be a bit slow but worth the wait
#66 | |
http://www.hydrogenaudio.org/forums/...hp/t75166.html I should probably mention that only the MS tool flagged it as a trojan, AVG, malwarebytes and several others did not even report it. Last edited by PB2; 14th December 2009 at 09:15 PM. |
#67 | |
![]() But no kidding, if you have to put 2000 CD’s on a NAS dBpoweramp, is much more comfortable/faster and does 95% flawless in one pass (provided Accuraterip data is available). Also tag lookup for classic music is much better, although not as good as I would wish. |
#68 |
Just like to find out how many here is ripping their CD at the highest speed their reader can go?
Most driver have higher error rate at top speed and I just wonder if highest speed -1 or -2 is a better option or it doesn't matter since the ripping software like EAC or dBpoweramp will take care of this? |
#69 |
Hi if you have a large number of cd,s to burn in a given time scale then i guess that speed is of the essence if like myself you dont have a large number (i just burn the as i buy them) then the lowest error rate is the best in the long run.
#70 | |
No it is not possible (unless you take 4 billion to 1 odds), another persons rip with errors would not be the same as your rip with errors if they are different discs (the damage is different). A confidence of 1 is all you need for a bit perfect rip.
Spoon- dBpoweramp & AccurateRip |
| Lossless format & ripper? | rick57 | Digital Source | 5 | 25th October 2006 01:50 PM |
| New full (!) Lame front-end with CD ripper! | Alex.S | Everything Else | 0 | 6th November 2005 06:57 AM |
| Page generated in 0.12718 seconds (81.23% PHP - 18.77% MySQL) with 10 queries |
