PC Based Computer music servers, crossovers, and equalization
FreeNAS - Anyone Tried it as a Music Server?
Old 1st October 2009, 03:25 AM   #61
PB2 is offline PB2  United States
PB2's Avatar
Default Intel Gigabit Card
http://www.newegg.com/Product/Produc...82E16833106121
Old 1st October 2009, 03:33 AM   #62
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by PB2 View Post
A software/Unix guru friend of mine suggested this as an alternative to FreeNAS:
http://www.geek.com/articles/chips/f...u-810-2009065/
He's not tried this one at home, or FreeNAS, but he thought the above system based on Ubuntu might be easier to get going. They're both free so no loss in trying them. I might just try this one first since I also want to try Ubuntu on some other systems.
In my day job, I work with a lot of enterprise storage. One of my gripes is that the storage vendors basically give the disks away for free, but make money off of the software. It's a gimmick, like ninety nice cent two liters of soda at the supermarket.
Due to this, the disks at work are frequently antiquated and slow.
In order to prove my point, I built a NAS using OpenFiler, and it absolutely *smoked* the performance of our multimillion dollar Storage Area Network.
The guys at work weren't too happy about that.
Anyways, you can get wicked performance out of "free" solutions like OpenFiler. Sun's ZFS is neat too.
Have fun.
Old 1st October 2009, 03:43 AM   #63
PB2's Avatar
The Fujitsu Eagle was the hot drive around the time of my first hardware design job involving mass storage. The controller was the Zylogics 440 2 Multibus board set with a microcoded bit slice, and then the 450 where they got it down to one board.
Now that's a disk drive, $10,000, 600W, 470 MB, 130 lbs:
http://museum.ipsj.or.jp/en/computer...disk/0013.html
Takes 30 seconds to spin up.
IIRC, the blower on it (for cooling) was so loud that you had to raise you voice to
talk over it, if you were anywhere close to it, LOL!
Old 1st October 2009, 02:07 PM   #64
PB2's Avatar
Have fun.
It wasn't too long ago that they were using relatively low capacity but fast 10-15K RPM SCSI drives in enterprise systems:
http://www.newegg.com/Product/Produc...82E16822332010
Is this what you're talking about? Or something much more high end being that you mention multimillion dollar systems. I find that in most businesses hardware is kept for a very long time because it is so much more expensive and any change might cause down time. Only companies that require the latest and fastest to succeed upgrade often IME.
Pete B.
Old 1st October 2009, 02:34 PM   #65
PB2's Avatar
Default FreeNAS as a Print Server
http://www.instructables.com/id/Free..._Print_Server/
Old 1st October 2009, 03:22 PM   #66
ChrisA is offline ChrisA  United States
Have fun.
It all depends on how you measure "performance". To use a car analogy is it how long it takes you to get to work or how long it takes you to move 100 tons of crushed rock across town. It first case a fast motorcycle would have better performance but and old dump truck would beat it hands down on the second test.
A PC running FreeBSD is like the Motorcycle. See what happens if you try and serve 2,500 desktop machines with your "fast" server.
For home use, of course you want the motorcycle.
The other way to measure is "performance per dollar" or performance per watt of power. The PC based "fast" server may loose if measured that way
The best why to grade a system is if it is well suited to its purpose and no more costly to it needs to be for that purpose.
(agree about ZFS. I'm a long time Solaris fan and user going back to the eary SunOS days when it was MC68000 based.)
Old 1st October 2009, 11:28 PM   #67
PB2's Avatar
Not sure if FreeNAS will take advantage of the system ACPI sleep modes. Seems the options in the menus are for the drive, but they do seem to refer to the system also.
Just uploaded a 12.6 GB directory, and saw 85 to 95 MBps reported in the monitor, and about 50% CPU utilization.
Old 2nd October 2009, 03:17 AM   #68
PB2's Avatar
I have a nice clean 800 MHz P3 tower here that would also work well. It idles at about 74 W, 73 W with the disk spun down. Can't get it to go into standby mode.
The Dell P4 tower draws about 6 W in standby.
Old 2nd October 2009, 03:39 PM   #69
PB2's Avatar
Default Power Savings
Doesn't seem that FreeNAS will take advantage of S1 or S3 power saving modes. It would be a nice feature for them to add:
http://ask.metafilter.com/87443/Tips...FreeNAS-server
Old 2nd October 2009, 04:17 PM   #70
PB2's Avatar
Default Stanby mode tips
http://sourceforge.net/apps/phpbb/fr...hp?f=10&t=2125
http://sourceforge.net/apps/phpbb/fr...c853d70a#p2215
https://apps.sourceforge.net/phpbb/f...start=10#p2667
Not working yet for this system.
FreeNAS - Anyone Tried it as a Music Server?Hide this!Advertise here!
Music server with TDA1541 (I2S direct) ChuckT Digital Line Level 22 27th August 2010 07:53 AM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
Digital Audio Music Server kevinkr Digital Source 79 25th June 2008 05:29 PM
Wireless music server mods anyone mlihl Digital Source 12 8th November 2006 01:54 PM
Reclock music server ackcheng Digital Source 3 28th February 2005 03:21 PM
