| PC Based Computer music servers, crossovers, and equalization |
#171 |
I see... None of this really makes any sense to me.
Is the XMOS board usable as is? |
#172 | |
#173 |
I use quite an array of kit but the core is:
Asus M3N78pro mobo, AMD X4 Phenom, Windows 7 64 Ultimate on Seagate 1.5 TB drive for music storage (actually 3 x 500 in RAID). Ripper is EAC, playback either XMPlay or Foobar - soundcard is Soundblaster Live USB at 24/96 and with the new Win 7 drivers from Creative it never sounded better. In fact the improvement over the previous 64bit XP set up astounded me. I rip my LP's via a Sansui AU777 or an AU6800 off a Thorens TD125 with rebuilt SME arm and Ortofon cartridge straight into the USB box. Always use WAV for LP's (via Wavelab and Wave plug-ins) and restore to FLAC; everything else ripped to FLAC. Listen thru ML Aerius speakers, Technics SE-A3 amp and Angstrom 200 front end. Extremely satisfied with results. |
#174 | |
I just switched to cPlay for playback software and it is a significant improvement in sound quality over both Media Monkey and Foobar. Check out cMP² | Main / HomePage . Hardware wise, I switched from the Asus Mobo's spdif output to a RME Hammerfall card running SPDIF to a modified Behringer DEQ2496 (AKM 4396 dac and BB opamp output stage) |
#175 | |
What I have learned is windows 7 gives a much purer sound that XP, which has been a revelation to me (also revealed by the new DAC). Works very well:- YouTube - idiocratease's Channel |
#176 |
Hello Idiocratease, Your system looks really great. The Chord DAC with it's buffer and clock re-generation obviates the need for a low jitter interface that the ASIO driver and cPlay offers. It will be interesting to compare a cPlay, cMp ASIO sound card combination against Windows 7 and the Creative Card played into the same Chord DAC.
#177 |
are any of you guys using a quality DAC like the apogee DA16 or Dave Lavry Blue for your PC playback systems? What is your impression of these?
I'm looking for a new multichannel interface/soundcard/DAC, these are on my short list. Please help! |
#178 | |
#179 | |
That said in blind tests it seems very difficult to tell the difference between the classy Apogee and the comparatively lowly Echo Audio AudioFire. Apogee does not support Windows anymore btw. Interesting Converter Comparisons ... - Home Recording |
#180 | |
| Page generated in 0.13970 seconds (84.41% PHP - 15.59% MySQL) with 10 queries |
