Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 5th December 2009, 01:02 PM   #161
Key is offline Key  United States
Idiocratease do you use ASIO and foobar when you use XP? If not most likely kmixer/direct sound has been resampling your audio badly on the fly when you use XP.
Old 5th December 2009, 01:14 PM   #162
No, I had it on 'good authority' from Marian that their drivers by passed the kmixer (assuming you're using the native sample rate of the input file). So I suppose this must be correct as they write the software, so I suspect that somethign else was going wrong.
Now however, I've ditches Marian Marc 2 and XP for the X-Fi under Win 7. Significant improvement.
Old 5th December 2009, 01:19 PM   #163
Here's a couple of pics of the system...
...Zero noise from the PC, no fans, not hdd noise, no artefacts
I don't want to speak to soon.... But I genuinely feel as if I can stop messing around with the system and just listen... (Maybe when I get my next place some B&W 802D !)
Old 9th December 2009, 01:39 PM   #164
frenzic is offline frenzic  Netherlands
I use a marian prodif pro with the "xp non resampling" marian drivers for xp and i did also detect some garbage in the high end of the spectrum. I used xp sp3 with foobar and found this problem using both A and D outputs in foobar. So I also figured Kmixer was still not shut off. So I set the marian asio driver in foobar and the problem is completely gone. Hope this helps.
Old 10th December 2009, 07:21 PM   #165
Thanks. I'm glad to know there is someone else who can kind of validate what I've observed. Anyway, as I mentioned earlier, and nice inexpensive option of the Creative X-Fi Titanium seems to work perfectly under Windows 7.
Old 14th January 2010, 09:16 PM   #166
Netdewt is offline Netdewt  United States
Sorry to interject, but I'm hung up on this asynchronous vs. adaptive stuff. I read this:
Asynchronicity: A USB Audio Primer | Computer Audiophile
So, basically, in order to use USB (which I have to with a Mac laptop, I don't see a digital out anywhere) without a ton of jitter, I'd have to buy a gazillion dollar DAC? There is just so much snake oil in this hobby...
Would you guys say for sure that it's best to not use USB?
Old 14th January 2010, 09:37 PM   #167
gurley123's Avatar
Netdewt,
I use an Enhanced USB Monica from DIYParadise. I got the caseless version @ about $180 usd. Paired up with my Mac Mini running lossless files, this thing beats the pants off of any digital front-end in my system.
If you want to get a full on headache, read this whole thread here. I think the whole thing died when someone found this thing for $150 (still too rich for my blood considering you still need a quality DAC on the end of it.)
Old 14th January 2010, 09:53 PM   #168
Wow, interesting...
A key factor in the reproduction of high quality audio, the reference design’s unique asynchronous clocking mode achieves sub-3ms roundtrip latency, making it suitable for live music playback. The credit card sized reference design board will suit the development of speakers, home theatre systems, sound cards, musical instruments and professional audio equipment.
Gordon Rankin, Chief Scientist at Wavelength Audio, a designer of award-winning USB DACs said, “I’m glad to see XMOS producing a USB Audio 2.0 solution that’s clearly focused on achieving excellent sound quality. In particular, its asynchronous mode is a vital ingredient in the reduction of digital audio jitter which results in superior sound reproduction.”
$150... hmm... https://www.xmos.com/products/develo...kits/usbaudio2
Old 15th January 2010, 03:55 PM   #169
Then there's this. It says it's an ASRC (Asynchronous Sample Rate Converter):
The Metronome ASRC Module
Old 15th January 2010, 04:47 PM   #170
phofman is offline phofman  Czech Republic
ASRC is something else than asynchronous audio USB.
Page generated in 0.13039 seconds (80.67% PHP - 19.33% MySQL) with 10 queries
