| PC Based Computer music servers, crossovers, and equalization |
#141 | |
But as you are using a Mac, thinks will (I suspect) be very different, and you may well benefit for the interpolation of the native data. My DAC (QDB76) does huge amount of upsampling and transient alignment. I have never heard such clarity from a 'CD Quality source' as from this DAC. I've enjoyed the discussion between us on this! |
#142 | ||
As I know, so far, I'm not an expert of this field, oversampling is introduced for digital anti-aliasing filter. BTW, on Taipei 2009 HiFi show, I heard most clear sound of the show from PS audio PerfectWave, which also puts a lot of effort on jitter elimination. Well, we have gone too far away from the subject of this thread, but I believe, jitter elimination is a key point of computer based HiFi. I had worked in PC industry more than 10 years. I'm sure those PC makers will not put much effort on audio quality. We have to take care by ourselves. So far, seems like optical link + buffer + async precise clock is a good choice... |
#143 | |
Don't forget USB, I think USB has an undeservedly bad reputation. It passes the data, it is up to the device receiving the data to deal with it in an appropriate fashion to deliver good sound. Below is a quote from AMB Labs regarding the new Y-2 or Gamma-2 DAC. It has a USB input along with coax and optical. Notice the ASRC and clocking.
#144 | |
If this is how the data is metered out, then souce clock jitter would be an issues with USB, unless the data is buffered and re clocked in the DAC (like in my DAC). Do you happen to know ? |
#145 | |
Well I spent some hours attempting to come up with some concrete info for us and ended up more confused than ever. My conclusion was that re-clocking the data and a good clock are essential for using a USB type DAC, so my thoughts on the Gamma 2 hold. Here is an article by John Swenson that I copied from The Audio Asylum that describes the USB spec and modes of transfer that I found the easiest to understand. Hope it helps.
#146 | |
I appreciate your reply and will continue to look into this. Thanks, |
#147 | |
6moons audio reviews: Wavelength Audio Brick USB DAC I was quite encouraged by reading this:- "About USB's advantage over S/PDIF? The latter is unidirectional. USB is not to insure that the data on the hard-drive is identical to what streams out. According to Gordon, "the USB interface is asynchronous to avoid the clocking problems of S/PDIF. The Brick tells the computer it can do 16-bit audio at 32K, 44.1K and 48K. Since the USB receiver only has to handle these 3 frequencies, the clocking to the separate DAC IC has almost no jitter. S/PDIF actually has to be sync'd to the exact frequency of the transport (i.e. if the transport is working at 44.0896K instead of 44.1K, the DAC has to sync to that frequency). Therefore, the jitter problems of S/PDIF almost vanish using USB. With USB, we have a zero error protocol to link the computer to the DAC and very low jitter." However, at the end of the article I read the following:- "Basically the problem with PCs aroused in XP (I think this is when it started or maybe in a later version of Media Player) is the Kmixer. The Kmixer looks at the audio output and determines the highest rate. Then it automatically (even if it is 1:1) upsamples any sample output to USB to the highest rate (48/16 for my stuff). You can use ASIO4ALL with applications like Meedio, Foorbar and other front end programs. This will bypass the terrible Kmixer to result in superior output signal." This plays to my concern about the path of the signal inside the PC, before it even gets to the USB plug... I earlier mentioned that I was not 100% happy with the sound I hear from the UBB (9th Nov, 06:57 PM), and I wondered if the routing inside the PC (kmixer/drivers etc) might be the root of the problem. This article seems to support this possibility. I know for a 100% fact that up-sampling in via the kmixer has a deleterious affect on the sound (when in should improve, or at least do no harm). So my gut feeling is even a 1:1 sampling in the kmixer might have an adverse effect. At least I know using the Marian Marc 2 soundcard that the kmixer is avoided... I suppose then we should be looking for USB drivers which are audiophile and avoid the kmixer? I shall start to look.... |
#148 |
One thing for sure, regardless of what interface, you need to try to keep the signal as unadulterated as possible.The last thing you want is the OS doing what some one else told it it was "best" to do IE: kmixer.
To that end, on a PC, with windows, use something like foobar that allows you to use ASIO4all, WASPI or some type of Kernel Streaming. I use foobar and ASIO4all. It works well and is fairly simple to use. I use it for all interfaces and all of my DACs |
#149 |
Hi John, yes, makes perfect sense. I like to use windows media player. I did find an ASIO driver for this, but it did not work well.... I have 0.5 TB of media files, and windows media player does provide a great interface, but it also is a limitation... I'm wondering if I should start to chase microsoft about USB drivers to aviod the kmixer...
Interesting stuff... Thanks.
#150 |
Give foobar a shot. I have a bit over 2Tb of stuff and have really kind of given up on the use of a music player to manage it. Most of my collection is live music. I arrange my music by live or commercial, then by band. If live after band it is broken down into years and venues. This is how I store it on my disks. To play I choose what I want and drag and drop into foobar to play. Sometimes I'll drag a few days worth over and listen that way. Then I just highlight and delete then drag in some new stuff (it doesn't delete the files just the list). I convert stuff to mp3 for my portables and tag as needed to get it usable there. Kinda hit or miss but works well for me as I am a bit hit or miss myself.
Anyway give foobar 2000 a try, you can then configure your outputs with ASIO4all be they USB, spdif, etc. I think you will be pleased. |
| Page generated in 0.18734 seconds (88.83% PHP - 11.17% MySQL) with 10 queries |
