| PC Based Computer music servers, crossovers, and equalization |
Has anybody tried one of these??? To me, for $30 it doesn't seem like you could go wrong.
Any comments, problems, tips, etc would be appreciated. Thanks,
- Ray |
#2 |
I tried one based on many favorable comments I saw on the web. I was very disappointed. The sound just seemed flat (I mean lifeless) with an uncomfortable edge to it. In this case I think you get what you pay for. A $30 DAC sounds about like you'd expect a $30 DAC to sound. There is no free lunch here IMHO.
Nihilism is best done by professionals. |
#3 |
I fully understand that a $30 device would not compare to a full-featured, all-the=bells-and-whistles DAC. Nevertheless, my question was pretty vague... Let's try again
Does the Turtle Beach Micro sound better than the typical 'soundcard' built into a modern mid-level priced LapTop??? Thanks, - Ray
- Ray |
#4 |
I have used one of the turtle beach USB adapters with optical out. Using the optical out It sounded better than the analog out of my dell laptop. I did not try to analog out.
#5 |
Same. Bought one years ago for SPDIF out of a laptop - 16bit/48kHz limited optical worked fine and passed DTS/DD. Analog out works but I never really used that or listened to it seriously. The rubber coating got weird and gummy after a few years.
#6 |
The chip inside the Turtle Beach "Audio Advantage Micro" is supposed to be the C-Media CM102S. I ran across this chip in a cheap USB sound adapter from Radio Shack. It sounded OK with headphones, although the volume control didn't have enough steps. The chip has an S/PDIF output pin, and the pins are big enough to connect to fairly easily. It's encouraging to hear that it should do DD/DTS passthrough, so I may just convert that dongle into S/PDIF only.
There's a RightMark test of the TB AAM here: http://166.70.233.190/rmaa/Turtle%20...ge%20Micro.htm Not bad, although IMD is relatively high. |
#7 |
Devices based on the Burr-Brown USB audio chips may be better. Those are used in some boxes priced in the hundreds of dollars, if that means anything. Specs are better than the C-Media chips. About the cheapest thing I've found that uses Burr-Brown is the ADSTech "Instant Music" USB sound thing, or there's also the Behringer UCA-202 that uses the identical chip. From looking inside the ADSTech box, it is very close to the evaluation design that Burr-Brown describes, down to the resistor values in the low-pass filters. It includes RCA line-level in and out, and Toslink S/PDIF in and out, and was made in Taiwan, not China. The Behringer UCA-202 also has line in and out, S/PDIF out (only), and headphone out. Someone did RightMark analog loopback tests on them both, and the ADSTech performed slightly better.
#8 | |
Apa's DIY
YouTube - DIY speaker demo I am more than satisfied of the sound from my flac-TB - speakers. Definitely worth the $$ IMHO. I will guarantee it will be better than builtin laptop sound chip. gychang |
#9 | |
For the better sound effects,I think use an External DAC and USB-SPDIF device is a good idea. |
#10 |
FYI - There's a mini-review posted on the Anything But iPod site (Anything But iPod - MP3 Player Reviews & News).
I am NOT a shill for them - or anybody else
- Ray Last edited by sandbasser; 14th November 2009 at 11:14 PM. Reason: added disclaimer |
| Turtle Beach Audio Advantage Micro: $25 | gychang | Swap Meet | 0 | 26th January 2008 01:24 AM |
| Bash Sony's New "Micro Home Theater" | ak_47_boy | Everything Else | 3 | 28th May 2007 11:37 AM |
| Does anyone use TURTLE BEACH Audio Advantage Micro | Angelm | Digital Source | 0 | 25th April 2006 01:11 PM |
| Turtle Beach Santa Cruz sound card | peranders | Everything Else | 2 | 11th November 2004 01:15 PM |
| Page generated in 0.14636 seconds (83.54% PHP - 16.46% MySQL) with 10 queries |
