Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 19th October 2009, 06:42 PM   #231
that xmos thing looks very very nice if you have a good D/A idea too. Hopefully its around 150usd?
I really hope we see some decent D/A ideas , because this interface talk is getting old
Old 20th October 2009, 09:35 AM   #232
NeoY2k is offline NeoY2k  France
This XMOS thing is great news! We could now more easily develop audio interconnection. The remaining thing would be to develop a low latency audio network for pro uses (it has Ethernet, Audiorail skipped the MAC and TDM audio data... Straightforward, cheap, works...).
When I see the code for an i2s receiver (given as sample code), I can't stop thinking: just setting the registers of a TC Dice or stuff like that is more complicated.
Plus you can do anything you want with that thing!!!!
Old 20th October 2009, 10:21 AM   #233
I would make a (cough) digital (cough) crossover . I would keep the 'pro' and 'oversample' , 'upsample', 'ringing' words out of it , as these are gathering very bad meaning nowadays...
-Journalists, you know...
Old 20th October 2009, 12:16 PM   #234
jkeny is offline jkeny  Ireland
Banned
It strikes me that these ICs could form the basis for a nice DIY project(the non-BGA ones anyway). Come to think of it, even the BGA ones can be used if a protoboard would be suitable SchmartBoard - The world's best circuit prototyping system Expensive at $45 each but maybe?
So who's going to be first to put one together? USB or Ethernet?
Old 20th October 2009, 01:33 PM   #235
Telstar is offline Telstar  Italy
<snip> I like this thingy
Originally Posted by anbello View Post
USB audio class 2.0 is capable of 8 x 24/192K channels
I hold my opinion until i hear how they sound, compared to firewire. The real bandwith is a little lower in usb 2.0 (theoretically higher), but in practice the sharing common to all usb devices can cause issues for critical tasks as realtime audio. In the worst case a dedicated pc is using at least another usb device (mouse or keyboard), usually two or three (VFD, IR).
When USB audio class 2.0 drivers will be available for all OS you can use these kind of device without proprietary drivers
Do you know when that'll be? I have Windows7, but I dont think it supports usb 2.0 audio yet. Maybe even linux will move sooner.
The response of the inner ear extends to at least 200khz - Dr W. Tempest
Old 20th October 2009, 02:51 PM   #236
Pjotr's Avatar
FYI, I am encountering no issues with my EeePC (1.6 Gig Atom CPU) running XP-Home, over USB 2.0 with my Musiland USB converter. Also connected are an USB mouse and USB IRC. Even playing a CD from a hooked up external Plextor USB DVD drive performs flawless. But ok, playing a CD doesn’t take the USB to its limits.
Old 20th October 2009, 03:22 PM   #237
Good to know
But you are not using 8 channels with ASIO, which are for me requirements for my crossover. I think some proprietary (or good opensource) asio drivers are needed, I dont consider asio4all up to the task.
Old 20th October 2009, 04:23 PM   #238
anbello is offline anbello  Italy
anbello's Avatar
I'am not an USB expert but on ICH8 datasheet (an example of what you could have as I/O controller Hub on your PC) i read:
"The ICH8 contains five USB full/low-speed host controllers that support the standard Universal Host Controller Interface (UHCI), Revision 1.1"
"The ICH8 contains two Enhanced Host Controller Interface (EHCI) host controllers which support up to ten USB 2.0 high-speed root ports. USB 2.0 allows data transfers up to 480 Mb/s using the same pins as the ten USB full-speed/low-speed ports. The ICH8 contains port-routing logic that determines whether a USB port is controlled by one of the UHCI controllers or by one of the EHCI controllers"
I Think this implies that if you have up to 2 high-speed devices and 5 full/low-speed devices there is no sharing of bandwidth and each devices talk to his UHCI or EHCI.
Example:
1 USB audio 2.0 device <--> EHCI1
2 USB 2.0 external HD <--> EHCI2
3 USB 1.1 mouse <--> UHCI1
3 USB 1.1 [other device] <--> UHCI2
I don't know when but i think that if there will be enough device of this kind microsoft will develop the driver and so will do some linux developers (i hope so)
Ciao
Andrea
Old 31st October 2009, 07:29 PM   #239
That xmos USB2 kit does look very interesting. More of a general purpose cpu environment rather than an FPGA which might make it a bit more accessable. If the price on the USB2 kit is low enough, it definitely seems to be worth a look. Maybe time to research the status of USB2 audio drivers in Linux.
Old 19th November 2009, 04:37 PM   #240
anbello's Avatar
Latest news on the XMOS solution:
XMOS USB Audio 2.0 reference design provides highest quality audio solution | XMOS
"The design works with the Mac OS-X 10.6 (Snow Leopard) Audio 2.0 native class driver, and XMOS has teamed with Thesycon to provide Audio 2.0 Class driver support for Windows."
Nothing on linux front.
They sell the board here:
https://www.xmos.com/products/develo...kits/usbaudio2
Ciao
Andrea
Page generated in 0.11980 seconds (80.43% PHP - 19.57% MySQL) with 10 queries
