Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 18th May 2009, 09:23 PM   #201
ejaouen is offline ejaouen  France
To me ADAT is the perfect simple way to do it, with the inherent bonus of electrical isolation between pc and dac.
The only thing still needed is a small diy board around wavefront AL1402G chip near exactly as described in its datasheet. This is very simple but still too complicated for me being a newby in creating circuit boards and soldering ICs.
I hoped the twisted pear guys would be interested in this project...
I will probably end up making it on a stripboard with a "soic to dip adapter" but this going to be a long task, knowing how fast and experimented I am...
Old 22nd May 2009, 09:12 AM   #202
Telstar is offline Telstar  Italy
Isn't ADAT limited to 16/44.1k per channel?
The response of the inner ear extends to at least 200khz - Dr W. Tempest
Old 23rd May 2009, 12:39 PM   #203
44100 or 48000hz is the limit yes (if you want the 8 channel possibility) ; but you can have smux which doubles the hz at the cost of reducing the number of channels.
Personnaly I have hard time hearing more than 20000hz so 44100hz sampling is enough !
ADAT is 24 bit capable (not 16bit only)
So I do not see any real limitation in ADAT.
Would it be 16bit limited then yes ADAT would be worthless...
Old 23rd May 2009, 01:03 PM   #204
So, from a board like the RME with 8 ADAT channels you could have 2 24/192k channels (if you find a way to do that)?
Old 23rd May 2009, 02:09 PM   #205
padam is offline padam  Hungary
My opinion is that the DAC used&implemented is more important than the resolution, I am perfectly happy using USB.
Old 23rd May 2009, 02:14 PM   #206
Hurtig is offline Hurtig  Denmark
Is this thread gonna end up with some construction, or just a lot of talkin???
Old 23rd May 2009, 04:18 PM   #207
Hi hurtig,
Design me my AL1402G pcb and discussion is finished ! (I prefer through hole components when possible) : many asking PC to DAC how will have the answer from you !
Bonus : AL1402G chip is inexpensive
Telstar :
All recent adat RME cards have smux working and I think there is a document on wavefront website explaining how to make their AL1402G ADAT receiver chip accepting smux. You can have four channel 96k or stereo 192k.
Old 4th June 2009, 03:37 AM   #208
Default Status?
Same question here. Are we making any real progress after 6 months worth of conversation?
Old 4th June 2009, 10:56 PM   #209
mr.duck is offline mr.duck  United Kingdom
Default Re: Status?
Same question here. Are we making any real progress after 6 months worth of conversation? [/B]
How about using existing solutions and making the best of it? Like a pro USB audio interface (doesn't need to be expensive)... with optical spdif output. Just except that it's going to be jittery as hell and clean it up later like with a spdif or IIS reclock module. Optical is nice because it isolates things electrically.
Old 5th June 2009, 12:45 PM   #210
The problem with this approach is to properly clean jitter, downsteam
device or devices will have to be expensive
Page generated in 0.09591 seconds (84.35% PHP - 15.65% MySQL) with 10 queries
