| PC Based Computer music servers, crossovers, and equalization |
#181 |
diyAudio Editor
Lots of good info about the Bel Canto USB Link 24/96 and some other
USB-S/PDIF converters in the new MAy Stereophile. IT uses a Texas Instruments TAS1020 to accept the USB , then on to a Crystal CS8406 chip to output S/PDIF |
#182 |
I suggested a 24/96 TAS1020 based USB interface on the support forum a while back. I have an older Audiotrak optoplay and the board is tiny and simple with minimal component count.
I assume with the Centrance firmware that Lavry and Benchmark also have licensed for their TAS1020 USB interfaces this should not be too hard. Of course this should come after the release of the AC1 Cheers Thomas |
#183 |
Texas Instruments TAS1020 is obsolete.
#184 |
Hi, can anyone tell me the the name of the new revision S/PDIF receiver? Also the current draw on the digital rail? Thanks in advance.
#185 | ||
Twisted Pear Audio |
#186 | |
The subject is a bit off topic, even if the chief moderator started with it. The *recommended" belcanto device is expensive, uses an old chip and is not future proof, no 192khz. Then there is also the USB/firewire discussion. The Weiss converter is even more expensive. At the moment I would use a cheap usb converter and ..wait, or probably you can find a M-Audio or Edirol firewire device, then you have an additional AD converter with a mic preamp for the same price as the belcanto. regards Andre |
#187 | |
#188 |
We are waiting for USB3 chips to come out.
#189 |
I don't think USB3 is due out until 2010.
#190 |
that's what I just read to . . .
but perhaps the chips come earlier ? ? ? ? ? ( and are backwards compatible ) |
| Page generated in 0.11144 seconds (84.15% PHP - 15.85% MySQL) with 10 queries |
