| PC Based Computer music servers, crossovers, and equalization |
#141 | |
Coreworks are selling an IP core not a chip. |
#142 |
francolargo:
I am not sure we understand each other. The compressed format you have was originally 44.1 or 48kHz? If you uncompress, i.e. convert back to wav (b.wav), it will certainly sound different than the original a.wav. Both a.wav and b.wav will have the same bitrate of 2 x 16 x 44100 = 1.4Mbps. b.wav will have a limited frequency range since the MPEG-4 coder cuts high frequencies. Now what I do not understand is why b.wav upsampled to 176.4 should sound worse than b.wav, while upsampling a.wav produces an improvement. |
#143 |
Hi Phofman,
What I know for sure is that the original compressed files are ripped at 256kb/s and play at 44.1kHz. I assumed that meant that during decoding, fewer samples were repeated in a serial fashion to fill up the bitrate to 1.4mb/s. That's the signal I don't want to upsample to 176.4 kHz. Frank |
#144 |
Mid-thread conclusion please: Are we better off using something like an Empirical Audio USB to Spdif converter, or something like a squeezebox duet (assuming both are run into a decent quality DAC)?
http://www.empiricalaudio.com/frComputer_Audio.html http://www.slimdevices.com/pi_duet.html |
#145 | |
The decoder kind of "plays" the frequencies, creating a new waveform (wav) somewhat similar to the original one. The new waveform does not repeat samples in a serial fashion, it just has a different shape from the original wav. Since it is a regular wav (PCM), its upsampling should produce the same improvement (if it is the case) as upsampling the original wav. |
#146 |
Interesting!
Perhaps with the mpegs I'm noticing an effect similar to one noted over on the ESS Sabre reference thread. http://www.diyaudio.com/forums/showt...12#post1735012 There it was observed that with a better DAC the poorer quality recordings actually sound worse. We ARE talking about subjective SQ, and in a similar way, perhaps the degradation of mpeg encode/decode is resolution dependent. I was not planning to re-rip most of my 'average'-quality recordings to a higher resolution but now am re-evaluating... It may be necessary to maintain two source resolutions, a lossless one for the living room and a compact one for the iPod... over-and-out, Frank in Mpls. |
#147 |
#148 |
Oops I forgot this was not the linux thread
Perhaps someone has produced a similar functionality for windows.
#149 | |
All of these apps will automatically transcode your audio on-the-fly when you transfer tracks to a portable player like the iPod. |
#150 | |
But in the end, all the alternatives do the job
| Page generated in 0.11350 seconds (82.76% PHP - 17.24% MySQL) with 10 queries |
