troubleshooting zv9
troubleshooting zv9
Old 13th April 2007, 03:33 PM   #1
neil_kaye is offline neil_kaye  United States
neil_kaye's Avatar
Default troubleshooting zv9
I have actually decided to strip and rebuild the entire channel but for my own edification i was hoping someone might offer up some advice as to what might be causing the following problem:
1. DC output from rectified transformer is 52V (on my other channel i am getting 48V). Is 52 VDC to high?
2. I get a very distorted sound out of the speaker and with hardly any volume. You can almost hear the beat of the music but that's about it.
3. I thought i had blown the JFET but i replaced that and i still have the same problem.
4. The amp did work at one stage and then something blew / popped ( i think i had shorted out my MOSFET's. Before it blew i had trimmed the DC to read half of the input. Once it had blown there was no voltage difference where i had measured to trim the DC. So i replaced the JFET and it's adjacent MOSET and now i have a voltage but i had to turn the trimpot way down to get it back up.
What do you think the problem is?
As i said i am sick of mucking around with this so i am going to rebuild the entire board. Do you think i need to rebuild the PSU?
Old 13th April 2007, 03:43 PM   #2
cviller is offline cviller  Canada
cviller's Avatar
Does it get hot? If not, then your psu is not loaded and it can easily climb a few volts higher than under normal operation.
Try to measure as many voltages and compare them to the healthy channel. If you find a difference, you'll be able to get a better idea of where to look for burned components.
Old 13th April 2007, 03:52 PM   #3
neil_kaye's Avatar
It does not get hot at all.. which as you stated means it is not loaded
What are the components that can blow?
Old 13th April 2007, 04:00 PM   #4
cviller's Avatar
With some voltages I might be able to give better guesses, but I think you should look at Q5 and D1 - pull them out at test them.
Check if polarity of C4 and C3 are turned correctly and that they are not burned.
Old 13th April 2007, 04:08 PM   #5
neil_kaye's Avatar
thanks i will give it a try.
A question about measuring voltages. What point on the board should i use to establish the ground and which the live. I imagine one of the points would be at the component being tested?
Old 13th April 2007, 04:10 PM   #6
cviller's Avatar
You should use gnd as reference for all voltages. Clamp you meters gnd wire on the leg of R1 which is connected to R7.
Old 13th April 2007, 09:57 PM   #7
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
troubleshooting zv9
look-ZV9 have sooooo much parts................
pull up (solder them out ) all active devices;
same with all diodes;
check each resistor ; if in doubt-unsolder one leg from circ and then measure.
change what is burned
put new semis in
re-set what you need
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
troubleshooting zv9Hide this!Advertise here!
need help troubleshooting an amp emremeydan Solid State 12 28th January 2008 10:16 PM
Zen V8 Troubleshooting moe29 Pass Labs 13 20th March 2006 03:44 PM
Help troubleshooting Zen V4 ophilip Pass Labs 18 11th February 2006 12:39 AM
help troubleshooting this diy pre-amp zobsky Tubes / Valves 21 2nd November 2003 11:06 PM
Troubleshooting MikeBike Solid State 3 30th September 2001 04:19 PM
