Magura said:
75W for an IRFP240 is no big deal, I have to my surprise had mine running much (as in very much) harder for a year by now....
Magura
Hi magura; do your MOSFETs sound different when they're run harder? I'm giving mine a cushy life... somewhere in the neighborhood of 30 watts per side.
I would have hated to have all those warm heatsinks and nothing to plug it into...carpenter said:Seems like correct thinking to me.
Yes, this is AFAIK a well known fact. Just keep the temperature down, and you will see that you can push things quite a lot further.....
Magura
Cloth Ears said:
Roboman said in his previous post that he had trouble when the MOSFETs he was using were dissipating 75W. At the moment, I'm pretty close to that and I'd rather not be buying replacements all the time (cost is one issue, heart is another).
Magura
Well, the test came to an end today
The IRFP9240 of the CCS went south (although in a boring and civilized manner).
When I wrote "running them much harder" it meant 44V 3A (132W) at 60degrees/C, this is the max. power dissipation according to the datasheet. A rough estimation would be something like 1000 hours lifespan.
Magura
Magura said:Well, the test came to an end today
Magura
Thanks for putting yourself in the "literal" firing line for this. It's always useful to know how long things will last when pushed (and 44V 3A is pretty well 'pushed').
It was the max I could make the fets work at under the circumstances. I actually went higher but then they went bang within minutes or even seconds
....but I sorta just had to see what actually would happen when pushed waaaay too far.
Magura
- Zv6-t?
