Old 8th April 2007, 04:54 PM   #1
hifimaker's Avatar
Default Debugging Over/Undershoot Issues with Aleph30
I appreciate the forums insights and suggestions to square off the waveform on the output of my Aleph30.
The input is a square wave from a signal generator set to 2vdc at 10khz. Scope setting is 1 volt per division.
The boards and parts are from the Aleph GB using BrianGT's boards.
Attached is a picture of the scope's display.
Thank you again for any insights.
-David
Old 8th April 2007, 06:03 PM   #2
hifimaker's Avatar
Just like when I tested my BOSOZ, I realize the neg phase input needs to be grounded.
Here is the scope measurement with a 10khz square wave at 1volt, and 1 volt per division.
Neg phase is grounded.
-David
Old 8th April 2007, 06:04 PM   #3
hifimaker's Avatar
Here is the scope measurement with a 10khz square wave at 2 volts, and 1 volt per division.
-David
Old 8th April 2007, 06:18 PM   #4
hifimaker's Avatar
Here is the scope measurement with a 1khz square wave at 2 volts, and 1 volt per division.
-David
Old 8th April 2007, 06:29 PM   #5
The one and only
Nelson Pass's Avatar
Something odd is going on there, but I don't know what it is.
How does it change with and without a load?
Old 8th April 2007, 07:54 PM   #6
hifimaker's Avatar
The previous measurements were without a load. Here's a set of measurements with an 8 ohm 100w non-inductive load.
10khz, 2 volt square wave on positive phase, neg phase grounded. Scope set to 1 volt per division.
-David
Old 8th April 2007, 07:55 PM   #7
hifimaker's Avatar
Measured with an 8 ohm 100w non-inductive load.
10khz, 1 volt square wave on positive phase, neg phase grounded. Scope set to 1 volt per division.
-David
Old 8th April 2007, 07:56 PM   #8
hifimaker's Avatar
10khz, .5 volt square wave on positive phase, neg phase grounded. Scope set to 1 volt per division.
-David
Old 8th April 2007, 08:11 PM   #9
hifimaker's Avatar
Here's the amp's schematic.
Old 8th April 2007, 08:16 PM   #10
Netlist is offline Netlist  Belgium
Netlist's Avatar
Do both the Aleph current source and gain devices work properly? What is the bias current?
/Hugo
Debugging a PIMETA headphone amp Atilla Headphone Systems 3 23rd April 2009 05:12 PM
Debugging TDA1541a DAC PSU FibCouple Digital Source 13 19th November 2008 01:59 AM
Debugging my Aikido Bas Horneman Tubes / Valves 38 1st August 2005 10:25 PM
Undershoot in Kwak clock 7 Niklas Digital Source 51 8th February 2005 08:35 PM
Debugging Quasi amp cm961 Solid State 7 3rd February 2004 11:54 PM
Page generated in 0.10088 seconds (78.19% PHP - 21.81% MySQL) with 11 queries
