I hooked up a 1khz 1vdc waveform generator to the input of my BOSOZ and measured the output before the attenuator.
The output is a 4.5 volt square wave. The bottom of the square wave is rounded. (See attached picture) The output from the signal generator is nice and square 1khz waveform on my scope. Any ideas for how I should adjust the BOSOZ to square up the signal? Thank you! -David |
#2 |
Did you measure the output with less input voltage? The BOSOZ works best when fed with a signal between 0,3 and 0,6 Volt. Perhaps 1 Volt is a little too much.
Just my two cents, Fox |
#3 | |
Formerly "jh6you". R.I.P.
I have thin idea about the square wave things. Nevertheless, the asymmetric edge rounding looks very unusual. The asymmetry explains that the internal capacitance of the amp seems to have different rates in charging and dischaging time--really unusual. Did you check the sq. wave at 10kHz too? |
#4 |
Here's the output with a 1khz .6vdc square wave. Scope is set to 1volt per division.
Top trace is BOSOZ output, bottom trace is the waveform generator. |
#5 |
Here's the output with a 10khz .6vdc square wave. Scope is set to 1volt per division.
Top trace is BOSOZ output, bottom trace is the waveform generator. Thank you for any insights! -David |
#6 |
DOH! My bad. I did not connect the - Neg phase of the balanced input to ground. After ground the neg input the waveform is nice and square!
10khz .6vdc square wave on the pos input, neg input grounded. -David |
#7 | |
![]() typical mistake-when someone choose to power up brain instead ears..................
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#8 |
My mistake rate is rather high in one per ten measurements. But, only once with the same kind . . . |
#9 | |
I screw it up everytime, especially when it has a zener in it somewhere.
Crazy Yankee. |
| Matisse Fantasy waveform output test | ckwong99 | Tubes / Valves | 35 | 11th January 2007 01:03 PM |
| SMPS output waveform discontinuities | b-ohica | Power Supplies | 2 | 29th November 2006 01:24 PM |
| x-BoSoZ volume on in or output | yoke | Pass Labs | 9 | 24th June 2004 06:43 AM |
| What output capacitor value for BOSOZ | macka | Pass Labs | 7 | 12th May 2004 08:00 PM |
| BOSOZ low output? | Brownlow | Pass Labs | 3 | 31st October 2003 11:26 AM |
| Page generated in 0.10145 seconds (75.67% PHP - 24.33% MySQL) with 11 queries |
