Old 7th April 2007, 04:16 AM   #1
d to the g's Avatar
Default pearl HELP!
So, I've been enjoying (immensely) my pearl for a couple of weeks now. Tonight I went to change the volume, and static jumped from my finger to the volume knob. At first I thought I lost the entire left channel, but now it's playing quietly, and using the volume control (50k noble pot) to "6" brings sound to a semi-listenable level. Normally I'm a "3 or 4" on by control.
I've done enough troubleshooting to know that it's definitely the pearl, and that it's just not playing as loud. Where do I go from here?
Old 7th April 2007, 10:29 AM   #2
cviller is offline cviller  Denmark
cviller's Avatar
You might have fried a transistor...
To find the problem, I think you should measure the voltages on your left channel compared to the right channel and waynes numbers. If some of the voltages are way off, you might have the problem in that area or in the circuitry connected.
Old 7th April 2007, 01:50 PM   #3
d to the g's Avatar
I was hoping that wasn't it. Thanks though.
Old 7th May 2007, 03:02 PM   #4
d to the g's Avatar
If anyone can help me with this:
Q4 was reading 0.7 V compared to the 13.8 on Wayne's schematic. I replaced this with a new ztx450, and I'm still getting the same reading.
Any ideas what I should go for next before I just start randomly replacing things?
Old 7th May 2007, 03:12 PM   #5
cviller's Avatar
What is the voltage between R25 and Q6? And both ends of R14?
Old 7th May 2007, 03:31 PM   #6
d to the g's Avatar
I'm not exactly sure where on Q6 I should measure. And from which side of R25? From the side of R25 opposite of Q6:
1 2 3 4
.794 .307 .308 .795
5 6 7
.758 .383 .758
If I measure from R25 on the "facing Q6", I would subtract .307 from each measurement.
The voltage across R14 is 28.07 V
Old 7th May 2007, 03:41 PM   #7
cviller's Avatar
When I say R25 I mean the voltage on the one leg which is not connected to ground. It is easier if you reference all voltages to gnd.
What is the voltage bias on Q4 - should be 14V?
Old 7th May 2007, 03:47 PM   #8
d to the g's Avatar
Q4 is reading ~0.78 V from gnd
The leg on R25 "away" from Q6 is the gnd, The voltage drop across R25 is 0.307 V.
Is R26 the additional resistor for cartridge loading? My cart is 47k, so I did not use R26.
Old 7th May 2007, 03:54 PM   #9
cviller's Avatar
On the base?
You should have something like:
28V -[R17] - 14V - [R20]- gnd
and the base of Q4 is connected between R17 and R20.
Seems ok...
I don't know why I wrote R26, I meant R25.
Old 7th May 2007, 04:14 PM   #10
d to the g's Avatar
On the base?
For Q4
Where Wayne has it marked 13.4 V, I'm getting 0.78 V.
Where he has it marked 19.3 V I'm getting 0.75 V
Where it's marked 14 V I'm getting 1.55 V
However, I'm getting a 27 V drop across R17... which definitely doesnt seem right.
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
The Pearl-X Vince Maida Pass Labs 12 28th July 2002 07:28 AM
Page generated in 0.09698 seconds (81.23% PHP - 18.77% MySQL) with 10 queries
