I'm planning to build this preamp and I have a few questions.Personaly,I think the input cap(C104/1µF) need to be a good one a Tin folie or better but what about the output cap(C103/10µF)?
#2 |
Use a good cap. If necessary, bypass with a decent film cap.
Grey |
#3 | |
is this a trick question? ![]() if signal goes through both caps,conclusion can be just one............
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#4 | |
If you can give me some good advice about building this preamp feel free. |
#5 | |
never mind;look at few pics: http://choky.on.neobee.net/My_BOZ.html
#6 | |
What about bypass with a Styroflex or a Roederstein MKP 1837 |
#7 |
Can I use a bigger output pot?Like 50K instead of 5K,so I can lower the output cap from 10µF to 2.2µF.
#8 |
The value of the DC blocking cap at the output is dependent not only on the value of the pot, but also on the input impedance of the amplifier.
Grey |
#9 |
using the original value for the volume pot, the output impedance will be 0- 1,5k depending on the position of the volume pot. If you increase it, the output impedance will be increased too. This would be a problem for your power amp if it has low input impedance. I have used a 10uF SCR polypropylene cap for output with good results. It's too expensive to use something "great" in this value. Regards Spiros
Where there is a "will" , there is a way! I hope... |
#10 | |
Hi, Look at the Sewa tread post #655 I'm wondering if I could replace the MKP 10µF for a 8.2µF? |
| New PCB for bride of zen | maartentje | Pass Labs | 6 | 28th February 2005 07:19 AM |
| Bride of zen PCB | maartentje | Pass Labs | 8 | 14th February 2005 01:26 AM |
| bjt bride of zen | renjiish | Pass Labs | 1 | 24th September 2004 03:54 PM |
| Bride of Zen, Bride of Son of Zen | 2Bak | Pass Labs | 4 | 12th May 2002 04:51 PM |
| Bride of Son of Zen vs. A;eph P | Peter Daniel | Pass Labs | 0 | 25th January 2002 07:45 PM |
| Page generated in 0.10172 seconds (78.15% PHP - 21.85% MySQL) with 11 queries |
