Have anyone built the PLH amp? Should we expect there can be a power-on pulse to the speaker?
I am planning to build one, and is not sure if I should include a Power On Mute or not. If I do so, will it hurt the MOSFET if the mute circuit is a NC relay short circuit of the output to GND? I prefer to use this instead of a NO relay open connecting the output to speaker as I want to avoid signal passing thru the relay contacts. Any advices? |
#2 |
Having built the A75, to my surprise it didnīt show any audible thump-sound at turn-on or turn-off. Within the first second of switching on, DC offset is max. 1,5 V, and itīs a soft shaped curve. I too disliked the idea of a relay in the loudspeaker-path, so i first tried without.
If you include a NC relay you may put a resistor in series, something like 1 to 6 ohms for limiting current. Anyway, plan on including it and keep us informed if you needed it or not. Norbert |
#3 |
The one and only
I don't recall a thump, but you can short the output if you
like - the Cap will protect it.
#4 |
| Speaker Mute circuit for power Amp | steevo | Solid State | 8 | 30th November 2008 02:30 PM |
| Want a simple power-off mute option | danielwritesbac | Chip Amps | 3 | 9th April 2008 05:41 PM |
| LM3886, power caps, input resistors, mute, and Cm. | mudihan | Chip Amps | 3 | 21st December 2007 09:23 AM |
| Mute resistor value | Lico | Chip Amps | 3 | 4th February 2005 04:40 PM |
| please help - no mute but did mute mod - tda1541 | loomis | Digital Source | 1 | 14th November 2002 10:54 AM |
| Page generated in 0.07146 seconds (71.07% PHP - 28.93% MySQL) with 10 queries |
