more words has spend about a mached mosfet, but the capacitance of gate is than more important in audio responce?
it' very easy mount a irfp250 in to247, the to3 case need too much drill-wole..... what thing about??? |
#2 |
I'm not clear what the question is.
Grey |
#3 |
You could try the IRFP240, its a TO-247 package. I could be wrong here but I believe you could use say 10 pairs of outputs vs. the original 12, to offset gate capacitance issues.
-john |
#4 |
the question is:
12 pair of IRF240 in to3 case as output stage is similar to mount 12 pair of IRFP250, the gate capacitances has a limit in aleph1.2? anyone has tested or listed a differences? thanks |
#5 |
I am not looking at a datasheet but I thought the IRFx250 was a bigger die than the IRFx240. Higher curent AND higher capacitance. Maybe you could get away with using less of them. This is only from memory .
Crazy Yankee. |
#6 |
have right, irfp have more gate capacitance, but are more easy to mount. was wondering for how much current and then how much make out can pilot with the first stadium of aleph1.
sorry for my english |
#7 |
There's more to it than just Gate capacitance and current capability. You need to keep an eye on the power dissipation.
Also, don't immediately assume that lower Gate capacitance is always better. It depends on the circuit and the application. Grey |
#8 |
but sharpen she makes out minor should extend the band and the answer of the pilot stadium, and not to load the driver but to give back the whole possible linear piu frequency range.
#9 |
I would like to avoid mounting 48 metal irf240 in to3, while I can choose to mount the same number of irfp250 to their place in to247, with remarkable advantages in terms of assembly and current, but not in make out of gates, while he remains the doubt of as it can worsen the sound of all the amplifier.
evaluates that all the amplifier assumes remarkable dimensions, a lot of to be become a monolith arranged in the lounge. the measurements correct in cm are 160 high, 24 narrow, 40 deep, and higher than 40kg of weight, even if of wood and dark a remarkable visual impact always has. |
#10 |
It also took me a while to understand what the issue might be.
According to IRF website, IRFP240, which is TO247 plastic package, is now obsolete. The next closest in TO247 is indeed the IRFP250. IRF240 (without P), which is TO3 metal can, is still active. But I think if you are quick enough, you can still get enough IRFP240 in TO247 on the market, e.g. www.reichelt.de www.schuro.de etc. Patrick |
| irfp250 application | sakis | Solid State | 9 | 11th April 2009 11:47 PM |
| IRFP250 die size | djQUAN | Solid State | 4 | 24th July 2004 04:32 PM |
| Irfp250, Irfp9240, Rifa | kims | Swap Meet | 1 | 30th April 2004 06:37 AM |
| Aleph-4 with IRFP250 | ruangrit | Pass Labs | 1 | 3rd January 2004 09:06 AM |
| I have a lot of IRFP240 IRFP250 to sell! | Cephas | Swap Meet | 0 | 23rd June 2002 11:26 AM |
| Page generated in 0.10712 seconds (76.75% PHP - 23.25% MySQL) with 10 queries |
