Old 11th February 2003, 09:51 AM   #61
Lucas_G is offline Lucas_G  Netherlands
Default DAC PCB
Peter,
This looks very nice indeed!
I have mailed you my request to buy one PCB from you.
Please tell us as soon as possible how it sounds!
Can't wait to hear it...
Lucas
Old 11th February 2003, 12:21 PM   #62
cHoc is offline cHoc  Netherlands
Send a message via MSN to cHoc
Originally posted by pquadrat
You can download schematics now:
www.neunelfer.de/DAC.zip
(available only for limited time, my web space is limited)
Parts list will follow.
uploaded to my webspace, so everyone can enjoy the scematics
http://members.home.nl/brunsting/DAC.zip
Old 11th February 2003, 05:50 PM   #63
Please do not ask for the boards now, all seven are sold, and I have three DIYers on the waitlist.
-Peter
Old 11th February 2003, 11:21 PM   #64
pquadrat,
Do you have any comment on the sound of the d1 coupled with the PCM1704? Why did you choose not to follow Uli’s advice on upping the output of the d1 stage to normal levels? Can you use this dac with a passive preamp? Do the 610 mosfets get hot?
uli,
I have printed the value changes you’re recommending in red next to the old values in red. Can you confirm these values? Look at the value of c15, c16 the value change seems drastic.
Someone should get in touch with the mediator of this forum and tell them we want to post PDF files without having to zip them.
Leve
Old 12th February 2003, 09:47 AM   #65
uli is offline uli  Austria
Lightbulb error
Originally posted by LBHajdu
pquadrat,
uli,
Originally there are 2,7 nanofarad! with PCM 1704 and 2k5 res.
it should be 1,5 nanofarad! = 0.0015µF. maybe you misread
that µ for an n!
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 12th February 2003, 06:34 PM   #66
pquadrat,
Leve
I'm using the D1 wiith sony's current pulse dacs - parts of a cd player- instead of the cd player op amps. The output level is quite high and capable to drive the Zen, Aleph X .In fact , currently I 'm not using a preamplifier (active) thanks to the D1 . Of course the Aleph ono do not need the preamplifier too IMHO.
The 610 do not get hot , they are running *only* 10mA par side.
The sound of the inside op amps of the cd player is long way not comparable with the D1 I/V stage.
The D1 is better , much better .
Sorry if this reply is not directly based on a experience with the PCM1704 ,but i'm sure you can obtain good results even with it.
The game is worth the candle.
Old 13th February 2003, 09:03 PM   #67
Is it possible to get the PCB design also ? I missed the oppurtunity to buy the boards from you but I really would like to make a similar DAC. I understand if I am asking to much
Carl-Fredrik
///CF
Old 17th February 2003, 12:21 PM   #68
first of all, I made a parts list.
Things You should know:
The output capacitors are not on the board, You have to put them between
PCB output and Your output connectors. See D1 schematics.
The relay has no pins to connect to the coil. You have to solder wires on the reverse side of the pcb to the relay.
You have to cut one trace between the rectifier bridges. it is the only straight trace between D1 and D2 on AC side.
You have to solder one of the wires of the transformer to the cut-of pin of D2 then.
Because of incorrect information in one data sheet, You have to connect pin 10 to pin 4 (-5V) on U1 and U3. U1 and U3 are inverting the signal then, neccesary for balanced operation.
Feedback on this design is welcome, maybe I will do a second version later this Year. With error corrections and improvements, but basically the same concept.
-Peter
Old 17th February 2003, 12:23 PM   #69
Carl-Fredrik
Please email me. Problem maybe file format.
-Peter
Old 17th February 2003, 12:46 PM   #70
-Peter
Hi Peter,
Would it be possible to produce a second batch of PCBs?
There must be at least another 10 people interested!
I, for myself, have long since dreamed of such a project with those highquality components...
Have you already listened to it?
Of course you should also earn a little on them...
Maybe?
Greetings,
Lucas.
Nice Heatsinks for Aleph Bengali Pass Labs 3 31st July 2009 12:22 AM
Nice way to add a headphone amp/plug to Aleph-30? h_a Headphone Systems 10 8th February 2007 02:28 PM
Bigggest Complement EVER Dominick22 Planars & Exotics 5 24th February 2006 12:06 PM
2SA483 Complement EchoWars Solid State 4 30th November 2004 08:14 PM
Found some nice Aleph power supply chokes today Panelhead Pass Labs 0 3rd April 2003 01:10 AM
Page generated in 0.39060 seconds (29.11% PHP - 70.89% MySQL) with 11 queries
