#321 |
Warmed up. You'll find that they drift a fair amount when the amp is just turned on, but after twenty or thirty minutes or so, you'll get pretty stable values.
The absolute value isn't really all that important unless you intend to run the amp near full power. The relative offset is the one to watch out for. Parts matching is your first line of defense. Then the circuit embellishments to fine tune things. Around this point, someone frequently pops up asking about using a servo. Yes, it can be done. No, it's not necessary to go to those lengths. Grey |
#322 |
Banned
GRollins
"The relative offset is the one to watch out for. Parts matching is your first line of defense. Then the circuit embellishments to fine tune things" thats what ive said, if you aim for high precision match! and use high precision components, high quality is the number 1 factor here if you cant attain these matches in components just follow the 5 ways mr Pass has talked about Mr pass thank you for the links |
#323 |
The other things are in addition to matched components, not instead of.
Grey |
#324 |
Banned
in addition?well i guess mr pass is on to something big
good luck |
#325 |
Petter
I would be very much interested to have a look at your last design of the x100 since Nelson doesn't mind about it. Another thing though, using 12 pairs of fets for 100w per channel is indeed an overkill unless you plan to go up to 600w with the same circuit?
Nick |
#326 |
Nelson wrote: "...so on the X350 we used a current mirror for a level shifter."
Could anyone explain how to do it on X100? |
#327 | |
The one and only
examples on this site. You source a certain amount of current into it and you get a certain proportional amount out. The ratio between input and output are arbitrary, and when the ratio is unity, it's a level shifter. |
#328 |
Uhmm, could be something like this?
The frontend in this thread is single ended, so I drew it this way. Could also be complementary I guess. Not sure if it would work. But it's more a conceptual schematic anyway. All this resistor values guessing... Ciao, Tino |
#329 |
The one and only
Yes, that would be an example.
#330 |
Now that's a cool use of the current mirror.
| Help needed: Firing up the Aleph-X100 | Blitz | Pass Labs | 86 | 22nd September 2010 09:09 PM |
| Fisher x100 | rudy129 | Parts | 0 | 11th February 2008 01:32 PM |
| Aleph DIY x100 and Wilson Audio-low impedance problem. | elviukai | Pass Labs | 11 | 9th March 2006 06:36 PM |
| Has anyone heard of the SPL-X100 speaker? | Matttcattt | Car Audio | 1 | 11th December 2003 02:58 PM |
