#112 |
It is hard to tell, but judging from the information I have up to this point as well as comments from Nelson Pass in this very thread, I suspect it is almost completely the same.
Read what NP said and judge for yourself -- last post on page 3. Photos will be forthcoming when I can get hold of a digital camera. Petter [Edited by Petter on 07-26-2001 at 05:20 PM] |
#113 |
Except for the small fact that Nelson uses 80 output devices instead of 16......The X-1000 dissipates about 600W per channel, so if you would have used only 16 output devices they would have a real tough job. Spreading the load, as Pass does, is the only way for these kind of high-powered and hot-running amps to last....(please bare this in mind)
Gordon Gekko |
#114 |
The clue to that is the name of the thread. Petter's got it covered. I guess he doesn't have a listening room the size of an aircraft hanger.
Jake |
#115 |
Functionally almost completely the same would be my best estimate.
Petter |
#116 |
The one and only
We routinely post project pics at our site,
and you are welcome to send them to dharrington@passlabs.com |
#117 |
This is work in progress. I will send pictures to you when project is finished and working -- then you can decide if you want them.
Petter |
#118 |
Mr. Pass
after you take the test, the teacher usually posts the keys... |
#119 |
diyAudio Administrator
I have uploaded Petter's pictures to this url (thank you Petter!)
http://www.diyaudio.com/projects/petter [Edited by Jason on 07-30-2001 at 12:57 AM] |
#120 |
Triplets: An Excel optimization model for creating compound resistors where current in trimmer is minimal, all turns of trimmer are used in desired window, and progressions is relatively linear.
Other files: Images of circuit. Don't laugh at the amateurish look + crammed board ... Please note: 1. Brass screws (no ferric materials here!) 2. Small dimensions of board 3. Lack og ground 4. Power supply comb pattern is "filler" to fill the board. I figured if I did this I would be able to find use for it. 5. Rounded features in PCB track corners. Also note what I did wrong: 1. PCB tracks could be thicker 2. Size could be made a little bigger 3. Mounting holes should be set up (not really a problem, but ...) 4. I ended up using larger resistors than expected (which is good because they don't modulate so easily but the pattern was a little tight for them. 5. Trimmers are too close to other things. 6. Pads could be a little bigger. 7. Transistors have a thicker side. If you put two of them together, that is about 8 mm of space which I did not plan for! Check out the central right transistor (top) and you will see what I mean! 8. Small silly things that amateurs do. But hey, this is my first print. There are also other modifications that could be done. Petter |
| Help needed: Firing up the Aleph-X100 | Blitz | Pass Labs | 86 | 22nd September 2010 10:09 PM |
| Fisher x100 | rudy129 | Parts | 0 | 11th February 2008 02:32 PM |
| Aleph DIY x100 and Wilson Audio-low impedance problem. | elviukai | Pass Labs | 11 | 9th March 2006 07:36 PM |
| Has anyone heard of the SPL-X100 speaker? | Matttcattt | Car Audio | 1 | 11th December 2003 03:58 PM |
| Page generated in 0.11413 seconds (77.88% PHP - 22.12% MySQL) with 11 queries |
