X100 backengineered here
Old 29th August 2006, 08:53 AM   #341
DarkOne is offline DarkOne  Slovakia
DarkOne's Avatar
Thanks for your rule of the thumb mr.Pass.
The distortion you are talking about is seen in my mesurements
Probably the reason why I could not hear the difference is that I don't listen very loud, so output devices operate in class A most of the time. When I play loud my loudspeaker start to resonate, so I don't hear amplifier's but loudspeaker's flaws. Maybe with new loudspeakers (in progress) I will hear the difference and decide to raise idle current to 3-4 amps (maybe more )
Robo
Old 27th September 2006, 08:25 PM   #342
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Default Re: X100 backengineered
Originally posted by Petter
I am very interested in feedback on this design (which is based on patents held by http://www.passlabs.com and thus not available for anything but research).
They forgot to patent a method of connecting of wires using high temperature.
The amp will defenitely work fine, but I'd add a servo loop to avoid the need to carefully match pairs.
Old 27th September 2006, 08:37 PM   #343
Wavebourn's Avatar
Originally posted by LBHajdu
I just wanted to draw peoples attention to this interesting push-pull X design. The author has built it and says good things about it.
http://www.diyaudio.com/forums/showt...0&pagenumber=1
Leve
Classical opamp with differential output.
Old 11th October 2006, 01:11 PM   #344
Villaw is offline Villaw  Cyprus
Has anyone managed to print our a pcb layout of this yet? I would be quite interested in comparing the sounds of these designs with other so called "famous" designs, even though 25w is well below the "ideal" power output for me.
Obviously dont want to infringe any copyright/patent protections here so Mr. Pass if I'm stepping on some toes here please let us know.
Nick
Old 11th October 2006, 03:57 PM   #345
DarkOne's Avatar
Default Re: Re: X100 backengineered
Why DC servo? It has DC offset about 30mV. Transistors are matched to get low DC on output, but more important benefit is less distortion, because matched transistors are mirror like images of each other (better cancelation of distortion).
Robo
Old 24th October 2006, 12:53 PM   #346
ZZZZZZZZZZZZZZZZ..................
Nick
Old 24th October 2006, 05:15 PM   #347
DarkOne's Avatar
PCB Layout is available (just email me toudy@chello.sk)
I have no comparsion with another "famous" designs yet
It's not 25W amp. My current amp runs +-24V power supply and can push more than 80W with less than 1% THD. I't bias has been set to give 25W@8ohm in class A, then it will switch to class AB at higher level.
Robo
Old 1st June 2007, 06:41 PM   #348
h_a is offline h_a  Europe
h_a's Avatar
@Petter: X5-service manual is now available! So if you want to further refine your X100, don't hesitate!
Cheers, Hannes
High Octane phono preamp Wiki
Old 2nd June 2007, 02:57 AM   #349
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Technically it's not. I recently sent a copy to a user with a need,
however you are free to distribute it discreetly via email on this
forum.
Old 2nd June 2007, 09:15 AM   #350
h_a's Avatar
Of course!!
Shame on me for not being more precise on that point!
I'm absolutely sure nobody here (including me) is going to handle such valuable stuff other than in a sense that has your thumps up!
Thanks and sorry for being not more clear, Hannes
X100 backengineered hereHide this!Advertise here!
Help needed: Firing up the Aleph-X100 Blitz Pass Labs 86 22nd September 2010 10:09 PM
Fisher x100 rudy129 Parts 0 11th February 2008 02:32 PM
Aleph DIY x100 and Wilson Audio-low impedance problem. elviukai Pass Labs 11 9th March 2006 07:36 PM
Has anyone heard of the SPL-X100 speaker? Matttcattt Car Audio 1 11th December 2003 03:58 PM
Copyright ©1999-2017 diyAudio
