X100 backengineered here
Old 29th August 2005, 01:57 AM   #321
GRollins is offline GRollins  United States
Warmed up. You'll find that they drift a fair amount when the amp is just turned on, but after twenty or thirty minutes or so, you'll get pretty stable values.
The absolute value isn't really all that important unless you intend to run the amp near full power. The relative offset is the one to watch out for. Parts matching is your first line of defense. Then the circuit embellishments to fine tune things.
Around this point, someone frequently pops up asking about using a servo. Yes, it can be done. No, it's not necessary to go to those lengths.
Grey
Old 29th August 2005, 02:58 AM   #322
mastertech is offline mastertech  Australia
Banned
GRollins
"The relative offset is the one to watch out for. Parts matching is your first line of defense. Then the circuit embellishments to fine tune things"
thats what ive said, if you aim for high precision match! and use
high precision components, high quality is the number 1 factor
here
if you cant attain these matches in components just follow
the 5 ways mr Pass has talked about
Mr pass thank you for the links
Old 29th August 2005, 04:27 AM   #323
The other things are in addition to matched components, not instead of.
Grey
Old 30th August 2005, 02:19 AM   #324
Banned
in addition?well i guess mr pass is on to something big
good luck
Old 6th September 2005, 02:36 PM   #325
Villaw is offline Villaw  Cyprus
Petter
I would be very much interested to have a look at your last design of the x100 since Nelson doesn't mind about it.
Another thing though, using 12 pairs of fets for 100w per channel is indeed an overkill unless you plan to go up to 600w with the same circuit?
Nick
Old 8th September 2005, 09:01 AM   #326
B.L. is offline B.L.  Poland
B.L.'s Avatar
Nelson wrote: "...so on the X350 we used a current mirror for a level shifter."
Could anyone explain how to do it on X100?
Old 9th September 2005, 08:04 PM   #327
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Well, you know what a current mirror is - there are plenty of
examples on this site. You source a certain amount of current
into it and you get a certain proportional amount out. The
ratio between input and output are arbitrary, and when the
ratio is unity, it's a level shifter.
Old 9th September 2005, 08:57 PM   #328
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Uhmm, could be something like this?
The frontend in this thread is single ended, so I drew it this way. Could also be complementary I guess.
Not sure if it would work.
But it's more a conceptual schematic anyway. All this resistor values guessing...
Ciao, Tino
Old 9th September 2005, 09:17 PM   #329
The one and only
Yes, that would be an example.
Old 9th September 2005, 10:43 PM   #330
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
Now that's a cool use of the current mirror.
X100 backengineered hereHide this!Advertise here!
Help needed: Firing up the Aleph-X100 Blitz Pass Labs 86 22nd September 2010 10:09 PM
Fisher x100 rudy129 Parts 0 11th February 2008 02:32 PM
Aleph DIY x100 and Wilson Audio-low impedance problem. elviukai Pass Labs 11 9th March 2006 07:36 PM
Has anyone heard of the SPL-X100 speaker? Matttcattt Car Audio 1 11th December 2003 03:58 PM
Copyright ©1999-2017 diyAudio
