X100 backengineered here
Old 22nd September 2003, 02:57 PM   #231
uli is offline uli  Austria
Default Aleph CCS
It is an implementation of NPs Aleph-CCS.
Kind of bootstrapped supply for the CCS regulator
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 27th September 2003, 05:37 AM   #232
john-china is offline john-china
john-china's Avatar
Default uli:hi
why original aleph ccs do not need this bootstraped supply circuit, but yours need this?
can you explain this detailed. if i design your ax100 , i will leave the transistor in aleph ccs alone , do not attach the mosfet(irfp9610) 's Drain . what is the advantage of your design?
Maybe i should not be lazy again
Old 27th September 2003, 03:45 PM   #233
Default bootstrap
Hi John,
If You look closely to the original Aleph CCS you will find
identical circuit except driving P instead of N Fet and the
zener added for safety reasons.
In fact you normally do not need the zener (just elco
protection)
Uli
Old 28th September 2003, 02:33 AM   #234
john-china's Avatar
Default haha
hi uli.
how stupid i am! yes , both circuit about bootstrap supply is identical. i read them too recklessly. thanks uli.
do you understand my second question about location of the transisitor in Aleph CCS.? maybe my language is too hard to understand. let me explain it..... maybe more explanation more
obscurity, haha.
i mean, in normal Aleph , the transistor of aleph ccs exists lonely,
do not attach any driver mosfet , it is only a part of CCS. but in your circuit , the transistor connects 1K attached by the drain of mosfet( irfp9620). i just think this transistor needn't be relational to irfp9620. why do you design such .? what advantage?
Old 28th September 2003, 10:25 AM   #235
Default connection
Hi John,
In fact it is not only connected via 1k to IRF9620
BUT also to output. The 1k is just a bleeder resistor
parallel to the power sourcefollower to define the
gate voltage of the outputfollower with the bias
current thru the IRF9620.
Uli
Old 16th June 2004, 04:28 PM   #236
Clarkcr is offline Clarkcr  United States
Clarkcr's Avatar
Petter, did you ever get a working X1000 up and running?
Old 16th June 2004, 04:35 PM   #237
Clarkcr's Avatar
Sorry, I'm still getting used to posting on this board. Had I noticed the dates and read all the way though I would know your progress up to a year ago.....however, my curiousity remains....what is the latest?
C
Old 17th June 2004, 12:12 AM   #238
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I believe that crowd moved on to Aleph X, which combines the
X circuit with the Class A Aleph output stage. You will find it
"permanently" at the top of this forum. From there, many have
become excited about Gain Clones, which has its own forum.
pass: / still likes the way Halo signed off.
Old 17th June 2004, 02:52 AM   #239
GRollins is offline GRollins  United States
I confess to being less than excited by chip amps, although I've got a couple of 3886s (or whatever the part number is...) lying around. I've always thought that Petter's investigations here were of interest. I have a couple of variations on the X circuit that seem fun to me, but then I'm easily amused.
It certainly wasn't my intention to put a damper on this thread by starting the Aleph-X thing.
So...just to see if anyone is listening...why not try for a class D X amplifier? The "X" aspect might be of use in removing residual nasties. Who knows, it might just be the ultimate subwoofer amp.
How's that for a blatant attempt to prime the pump?
Grey
Old 17th June 2004, 03:03 AM   #240
Sandy H. is offline Sandy H.  United States
Sandy H.'s Avatar
Default :(
I have to admit, the first amp that I built was of the GC variety, but my first and still most poignant draw to this forum has been the Pass section. I have a stack of heatsinks, Dale's Aleph 2 boards and the AX boards. The problem I have is dedication. The GC was too easy and therefore jumped up the list. I learned from it and hope to learn from the P3A that I am about to build (the first boards I ever bought).
As punctuation to this otherwise non-contributing response, I went to DIY Atlanta and heard a DIY Aleph 5. For the first time in my life, I heard something that was beyond real. To date, my goal is to complete the Aleph 2's I decided to try. Either I'm too chicken or too much the perfectionist to try it. If only courage came at 6:00, instead of at bed time. . .
Sandy. /Who misses the time when the activity on the Pass forum was the biggest on the site. . .
X100 backengineered hereHide this!Advertise here!
Help needed: Firing up the Aleph-X100 Blitz Pass Labs 86 22nd September 2010 10:09 PM
Fisher x100 rudy129 Parts 0 11th February 2008 02:32 PM
Aleph DIY x100 and Wilson Audio-low impedance problem. elviukai Pass Labs 11 9th March 2006 07:36 PM
Has anyone heard of the SPL-X100 speaker? Matttcattt Car Audio 1 11th December 2003 03:58 PM
Copyright ©1999-2017 diyAudio
