X100 backengineered here
Old 26th July 2001, 08:42 AM   #111
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
Anyone is welcome to host their projects on diyaudio.com. Just send me the files or the site you want uploaded and I'll make a space for it.
Old 26th July 2001, 10:17 PM   #112
Petter is offline Petter
Default How similar to the original
It is hard to tell, but judging from the information I have up to this point as well as comments from Nelson Pass in this very thread, I suspect it is almost completely the same.
Read what NP said and judge for yourself -- last post on page 3.
Photos will be forthcoming when I can get hold of a digital camera.
Petter
[Edited by Petter on 07-26-2001 at 05:20 PM]
Old 27th July 2001, 01:23 PM   #113
Gordon Gekko is offline Gordon Gekko
Except for the small fact that Nelson uses 80 output devices instead of 16......The X-1000 dissipates about 600W per channel, so if you would have used only 16 output devices they would have a real tough job. Spreading the load, as Pass does, is the only way for these kind of high-powered and hot-running amps to last....(please bare this in mind)
Gordon Gekko
Old 27th July 2001, 01:49 PM   #114
Jakeh is offline Jakeh
The clue to that is the name of the thread. Petter's got it covered. I guess he doesn't have a listening room the size of an aircraft hanger.
Jake
Old 27th July 2001, 07:03 PM   #115
Default Functionally
Functionally almost completely the same would be my best estimate.
Petter
Old 27th July 2001, 07:06 PM   #116
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
We routinely post project pics at our site,
and you are welcome to send them to
dharrington@passlabs.com
Old 30th July 2001, 03:54 AM   #117
Default Thanks NP
This is work in progress. I will send pictures to you when project is finished and working -- then you can decide if you want them.
Petter
Old 30th July 2001, 05:04 AM   #118
grataku is offline grataku  United States
Mr. Pass
after you take the test, the teacher usually posts the keys...
Old 30th July 2001, 05:53 AM   #119
Jason's Avatar
I have uploaded Petter's pictures to this url (thank you Petter!)
http://www.diyaudio.com/projects/petter
[Edited by Jason on 07-30-2001 at 12:57 AM]
Old 30th July 2001, 11:49 AM   #120
Default What are these files
Triplets: An Excel optimization model for creating compound resistors where current in trimmer is minimal, all turns of trimmer are used in desired window, and progressions is relatively linear.
Other files: Images of circuit. Don't laugh at the amateurish look + crammed board ...
Please note:
1. Brass screws (no ferric materials here!)
2. Small dimensions of board
3. Lack og ground
4. Power supply comb pattern is "filler" to fill the board. I figured if I did this I would be able to find use for it.
5. Rounded features in PCB track corners.
Also note what I did wrong:
1. PCB tracks could be thicker
2. Size could be made a little bigger
3. Mounting holes should be set up (not really a problem, but ...)
4. I ended up using larger resistors than expected (which is good because they don't modulate so easily but the pattern was a little tight for them.
5. Trimmers are too close to other things.
6. Pads could be a little bigger.
7. Transistors have a thicker side. If you put two of them together, that is about 8 mm of space which I did not plan for! Check out the central right transistor (top) and you will see what I mean!
8. Small silly things that amateurs do.
But hey, this is my first print. There are also other modifications that could be done.
Petter
X100 backengineered hereHide this!Advertise here!
Help needed: Firing up the Aleph-X100 Blitz Pass Labs 86 22nd September 2010 09:09 PM
Fisher x100 rudy129 Parts 0 11th February 2008 01:32 PM
Aleph DIY x100 and Wilson Audio-low impedance problem. elviukai Pass Labs 11 9th March 2006 06:36 PM
Has anyone heard of the SPL-X100 speaker? Matttcattt Car Audio 1 11th December 2003 02:58 PM
Copyright ©1999-2017 diyAudio
