Old 14th January 2003, 02:58 PM   #1
Default BOZ questions
I am building a BOZ and would like to use fixed resistors(instead
of 100k pot) at input,my power amp need 1.25v for full output. What value seem to be a good choice.
Also it seem that EB on TIP 29c are in reverse position if TIP29c
is well BCE(as per original article TAA/94 and Pass Lab site.
Thanks for your help.
Praudio
Old 14th January 2003, 03:51 PM   #2
Taco is offline Taco  Netherlands
You mean stepped attenuator? Or 1 volume level?
I had troubles with only a POT at the output, the amplifier distorted like hell. Now I have put a 100k resistor in series with the input. For the powersupply I used the BD139.
Old 15th January 2003, 10:56 AM   #3
SDF is offline SDF
Hi Praudio, you should calculate the resistor attenuator. it depends to the output voltage level of your source (CD player ) Give me it I will give you the result.
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
PSU for QSC amp questions rkc7 Parts 5 10th November 2005 05:18 PM
Last questions about this Madmike2 Multi-Way 9 13th June 2005 11:12 PM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 02:52 AM
Page generated in 0.06706 seconds (66.17% PHP - 33.83% MySQL) with 10 queries
