Old 26th March 2007, 06:10 PM   #1
svemir is offline svemir  Croatia
Default Aleph-X PCB
I have drawn aleph X PCB and I am wondering is it ok? Does it have any mistakes or some bad solutions in the layout!
Schem is taken from: http://www.kk-pcb.com/alephx.html
And here is the layout:
Old 26th March 2007, 06:14 PM   #2
And here is Scheme with component markings!
Old 2nd April 2007, 06:03 AM   #3
Send a message via ICQ to sk_tuner Send a message via MSN to sk_tuner Send a message via Yahoo to sk_tuner
my mail is sk.tuner@gmail.com
contact me please, i like your pcb project
sign. free
Old 2nd April 2007, 07:14 AM   #4
Paper mache horn fabricator
carpenter's Avatar
Are you mounting your power FETs on the pcb? If not, be sure to locate the gate resistor at the FET, and not on the pcb.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 2nd April 2007, 07:49 AM   #5
Mosfets are going on the PCB board, thanks for the advace obout Gate resistors but i am allready familiar with that.
Old 4th April 2007, 07:22 AM   #6
Francis_Vaughan's Avatar
Nice layout really. My only criticism is really one that is hard to avoid without a double sided board. The attached pic says it all.
Old 4th April 2007, 07:59 AM   #7
carpenter's Avatar
Hi Francis,
I'm not following your idea very well. Care to elaborate further? It seems you're drawing electrical loops, but I can't see what's causing them.
The Aleph X is a balanced circuit, so I assumed that electrons flowed evenly from the negative rail towards the positive. Come to think of it, the left and right portions of the pcb could be 180 degrees out of phase (+ and - input and amplification signals). Is this what causes the loops?
John
Old 4th April 2007, 09:47 AM   #8
Essentially what I'm trying to show is that as the current is steered about you get changes in the flow though the legs. The run across the middle is the speaker load. What I have drawn is an inaccurate extreme (I was too lazy to depict the remaining current in the active load legs - which is still very large). What it is, is an attempt to depict the dynamic current changes. Mirror image it for the other phase of the input cycle.
What you might get is the output coupling back into the circuitry in the middle of the board - especially if there are any reasonably large area loops.
Ugh, I just realised there is a no-no in there too. The drain resistors of the LTP go to different points on the -ve rail. That rail is going to see currents modulated by the signal on the two sides - just as I drew. The voltage drop (and there will be one even across a few cm of track) will leave a signal dependant voltage between the two halves. This is unlikely to help their tracking. They need a private trace between them, which is then connected top the -ve rail at one point only.
Old 4th April 2007, 10:59 AM   #9
Like this.
Should I remove R20/R19 and R36/R35 so they are not on the pcb and put them directly on the Gnd of the power suply central point.
Old 4th April 2007, 11:44 AM   #10
Yup. That was what I meant.
The principle is important in general. People worry about star grounds, but forget that any other high current leg with any modulation on it has exactly the same problems - and pretty much the same solution.
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.09772 seconds (79.46% PHP - 20.54% MySQL) with 11 queries
