hi
please every body i need a pre amp to drive aleph-x ihave no ideal which one will fit any one help? |
#2 |
I'd consider the BOSOZ/Balanced Line Stage on www.passdiy.com. There are other variants of the BOZOX on this site as well you might like to consider. The Aleph P is great if you can find a service manual.
A lot depends on your experience level as to which one to pick. The BOSOZ is a great preamp. -David |
#3 |
hi
i have an aleph-p diy but how do you keep it noise free ? when i used it at baranced input it run ok but unbalanced in put it seen have an hot noise very small but you know that the noise is there what can i do? please help |
#4 |
IT depends what kind of noise you are getting. If you are hearing a hum, there's probly a grounding issue. I'd check for ground loops. Try a star ground, tying all grounds to a common point. Also is the ground signal floating?
Do a search on this site for BOZOZ noise or grounding issues. There is a lot that's published on the topic. -David |
| Page generated in 0.08723 seconds (69.43% PHP - 30.57% MySQL) with 9 queries |
