Old 14th January 2003, 10:42 AM   #1
Mallard is offline Mallard  Germany
Question Unbalaced to balanced input transformer
Hi there,
this is my first thread here in this forum. It seems to me that this
forum will be quite an excellent source of informations for my
future SOZ project (more about it in another thread). And here is
my first question:
The origin SOZ design has a balanced input, but my CD-Player
unfortunately has only an unbalanced source. I found a good
answer to this question on the Jensen-Transforer page. They
recommend to use an input transformer, this would be the best
solution for that. Is this true? Has anyone made experiences with
that?
It would be great if someone can give me a hint!
Thanks in advance!
Mallard
Old 14th January 2003, 11:47 AM   #2
swede is offline swede  Switzerland
swede's Avatar
Easy.
Just ground the "cold" (negative) signal on the input and connect your CD to "hot" (positive) input and ground.
//magnus
Old 14th January 2003, 11:47 AM   #3
xsnailx is offline xsnailx  Poland
xsnailx's Avatar
Send a message via AIM to xsnailx Send a message via MSN to xsnailx Send a message via Yahoo to xsnailx
Default take a look
this link may halp you
http://www.diymania.net/pass/project/passpre.htm
Old 14th January 2003, 02:07 PM   #4
Paper mache horn fabricator
carpenter's Avatar
Default amazing link!
I've got a new BOSOZ folder started with the information on the site linked to above. What an impressive job!
Inspirational..........
Old 14th January 2003, 04:23 PM   #5
Send a message via MSN to Tazzy
Might have been nice if that website was writen in english
Old 14th January 2003, 04:58 PM   #6
xsnailx's Avatar
Default in english you say
i will try to contact my friends girlfrend
she is from japan and as far as i remmember she can read corean to
i will post the results if any
Old 14th January 2003, 05:24 PM   #7
Henrik is offline Henrik  Denmark
Mallard
The SOZ isnīt that happy with unbalanced input, I have tried it.
You did visit Jensen-Transformers homepage, and thatīs why I remembered this nice and informative discussion here:
Balanced line
Henrik
Old 14th January 2003, 05:28 PM   #8
swede's Avatar
So, what is the problem for you using the unbalanced input?
I've tried it, works fine.
You could build a BOSOZ pre amp, or something like it. Then you'll have balanced output. Simple and pretty cheap.
//magnus
Old 14th January 2003, 06:08 PM   #9
Shure it works, but you will get more distortion (not so perfect diffrential match), less gain and you also get some lower max. voltage swing at the output. SOZ does not have a Constant Current Source at the tail, if it had it woud be a better converter.
I agree that the BOSOZ would take care of thet and reasonable prised too.
Henrik
Old 14th January 2003, 06:09 PM   #10
Originally posted by Henrik
Mallard
Balanced line
Sorry I dont wanted to raise up such a big thread as you linked to. My Question is quite simple, I don't want to hear physical definitions and theorys.
Btw I don't know how much of it reflects only superstition.
Basically I only want to know what's the best choise for me in regard to how it sounds at the end! Thats all!
Thanks and Regards,
Mallard
PP to balanced input wicked1 Tubes / Valves 7 25th February 2009 10:21 PM
Line input transformer for unbalanced to balanced conversion okapi Chip Amps 23 12th January 2008 05:29 PM
Balanced Input Stage Bukitoo Solid State 5 11th March 2004 03:03 AM
Transformer at input of SOZ to convert unbalanced->balanced? psarin Pass Labs 29 29th December 2003 05:13 AM
[P68] Balanced input??? Tazzy Solid State 9 8th February 2003 12:52 PM
Page generated in 0.10632 seconds (81.73% PHP - 18.27% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
