Old 20th March 2007, 05:36 AM   #1
Tyimo is offline Tyimo  Hungary
Default X0 preamp question
Hi!
I have a question about the X0 circuit.
I attached the X0's inside picture. There is a section (marked with red line) what is not included in the sevicemanual's schematic but it is on the parts layout!
It has one 2sk389, one IRF9610, one 3.32K-5W resistor, one 100uF25V cap and a dozen of small resistors.
Could somebody tell me what is the function of that part of the circuit?
Thanks and greets:
Tyimo
Old 22nd March 2007, 04:40 AM   #2
Nobody??
Mr. Pass??
Old 23rd March 2007, 07:47 PM   #3
macka's Avatar
From the description it maybe SE (a single ended output stage.)
Normally you would use the balanced outputs but the SE stage allows SE connection to your power amps.
If you go to passlabs.com diy pages there is a great article on discrete opamps.
Old 24th March 2007, 08:53 AM   #4
rsbay is offline rsbay  Germany
It is a balanced to single ended stage build with a discrete operational amplifier with a single ended class a output stage.
Ralph
Old 24th March 2007, 12:00 PM   #5
Thanks Macka and Ralph!
I thought it is easyer way to make Balanced to SE like in the BOSOZ....
Is this Opamp something like in the Opamp article?
Greets:
Tyimo
Old 25th March 2007, 08:32 AM   #6
I think the discrete opamp consist of an input stage with a 2SK389 and a current source. The output driver is single ended build with a IRF9610.
Ralph
Uno preamp question john blackburn Chip Amps 14 15th February 2010 10:26 PM
preamp question sakis Solid State 4 17th July 2009 11:28 PM
preamp question overdrajv Tubes / Valves 7 28th December 2008 05:49 PM
Preamp Question! Lab_Rodent Solid State 9 5th December 2007 11:14 PM
Preamp Question mapiao Tubes / Valves 0 6th February 2007 02:41 AM
Page generated in 0.08804 seconds (70.32% PHP - 29.68% MySQL) with 11 queries
