I will make The Pearl Phono. Usually I draw the PCB and etch it by myself. The 2SK389BL can sometimes be hard to get, so now I have the opportunity to insert a replacement for this.
Is there any replacement for this? How will it be to use two 2SK170BL (or maybe others) in parallel and a 20 ohm resistor in series with each of them, similar to the first gain stage?
Roger |
#2 |
The one and only
2SK370's are coming from Toshiba, and they look to be an
excellent replacement.
#3 |
Also Linear Systems has replacements.
The 2SK389 and 2SK170 are both available from LinearSystems in Fremont California: http://www.linearsystems.com LSK170: http://www.linearsystems.com/datasheets/LSK170.pdf LSK389: http://www.linearsystems.com/datasheets/LSK389.pdf Both are available in the three traditional current versions: A, B, and C. -David |
#4 | |
#6 | |
What bias current are you using on the LS389B? The "B" grade is spec'ed at I_DDS 6-12ma at Vds=10V. Just want to get a rule of thumb..... Thanks |
#7 | |
#8 |
OK, folks. Thank you very much.
Roger |
| Wtb 2SK389BL & 2SB631K | gaborbela | Swap Meet | 4 | 7th October 2008 11:41 AM |
| FS- 2 X 2sj109BL and 2 X 2sk389BL | Luke | Swap Meet | 4 | 1st May 2007 09:05 AM |
| F.S. Toshiba 2SK389BL's | Mr Dijon | Swap Meet | 5 | 5th April 2007 08:35 PM |
| WTB: Toshiba 2SK389BL | cartman | Swap Meet | 3 | 9th June 2006 09:27 AM |
| F.S. 2SK389BL X 25 and other J-Fets | John Hinson | Swap Meet | 2 | 12th March 2006 01:28 AM |
| Page generated in 0.09940 seconds (77.66% PHP - 22.34% MySQL) with 10 queries |
