Old 17th March 2007, 07:22 PM   #1
elviukai's Avatar
Default anyone tried up aleph x input impedance?
hello fellows, I have o problem feed directly tube dac( 2x 6922 not SRPP, which has lower impedance.)anybody tried to up input impedance for aleph x? from 20kohmbalanced to 40-47kohm balanced. as I understand this is not only changing input resistors to 10kohm resistors to 20-23kohm..
anyone tried?
greetings
Rolandas
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!..
Old 17th March 2007, 09:16 PM   #2
elviukai's Avatar
anyone? is no one can anyone put me in right direction. I think many people would like to conect high impedanse sources(like tube dac) and have the same problem. I was very surprise that 10V rms(!) output (manufacturer claims 5V rms non HDCD and 10V Rms HDCD)are so weak comparing to 2V RMS low output impedanse ordinary opa amps dac. not speaking about muddy ,undynamic,not controled bass..
Old 18th March 2007, 05:41 AM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
which schematic exactly?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 18th March 2007, 08:32 AM   #4
elviukai's Avatar
its my vesion of aleph x . looks like kristijan and grey 100W amps. I using 220kohm resitors instead 100kohm to have better input sensitivity.
lets say it is kristijan schematic, only 100kohm changet to 220kohm. what direction to go when replacing 10kohm input resistors with 20-23kohm?
Old 18th March 2007, 09:07 AM   #5
Zen Mod's Avatar
input impedance is roughly sum of two series resistors (+ and - side);
you can up them to ,say, 27 K -but you must scale up 100K resistors for same factor (2,7x) . Also you must scale up (2,7x ) 10K resistors from inputs to gnd.
after that you need to scale down (2,7x) 10pF caps across (now) 270K resistors
try it like that-and if you have some problems with sensitivity, we will re-think what to do;
Old 18th March 2007, 09:57 AM   #6
elviukai's Avatar
thanks ,
so I marked resitors in schematic 1/2/3 respectively. so if I change R1 to 23kohm I will need also change 230kohm(which I already have 220kohm in circuit anyway) and also r3 to 23kohm??
Old 18th March 2007, 10:04 AM   #7
Zen Mod's Avatar
thanks ,
yup
1 and 3 to -you say-23K
2 you already have 220K
both 10pf to 3p9 if needed (best to see with CRO)
if you still need more sensitivity- increase 2 to 470K and decrease caps to 2p2............
in your boots-I'll make decent preamp
Old 18th March 2007, 10:11 AM   #8
elviukai's Avatar
hi, understad, will try this combination.thanks
as for preamps, I have few laying arround, but i hate preamps.
Old 18th March 2007, 10:35 PM   #9
Elviukai-
Do you have an oscilloscope?
I found using a high input impedence caused a phase variation between the channels of my aleph-mini amp. It was only a few degrees at 20kHZ, but could be seen very clearly at 100kHZ.
I don't know if it was from bad devices, or if this might be typical of all the amps, (unless someone took the time to match input devices in circuit).
If you do have a scope, once you have implemented Choky's resistor values, just feed the same signal to both channels and check the signal at the gates of the input devices to make sure it matches. Check both positives against each other at the same time, then both negatives.
Old 18th March 2007, 11:34 PM   #10
elviukai's Avatar
thanks, I do not have but I will bring amp to friend which have.
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
How much input impedance is enough? Russ White Chip Amps 5 13th April 2005 07:25 PM
Input impedance of Aleph X Peter Daniel Pass Labs 5 30th October 2002 05:28 PM
Increasing Aleph 3 input impedance Freddie Pass Labs 5 29th August 2001 10:52 PM
Page generated in 0.09135 seconds (86.01% PHP - 13.99% MySQL) with 11 queries
