Difference between IRFP240 & IRFP244
Old 13th March 2007, 11:25 PM   #1
Apogee is offline Apogee  United States
Apogee's Avatar
Question Difference between IRFP240 & IRFP244
I'm looking at ordering fets and would like to know which I should order.
Price is about the same so that isn't an issue.
The main issue for me is which sounds better???????
The 240 appears to be a higher current device so I'm thinking that is the best choice unless I'm convinced otherwise.
I will make sure they are all from the same lot.
Also, I no longer see the "N" versions listed on Newark's site. What's up with that? Are the N's the only versions now available or has IR dumped them?
On a side note, does anyone know a reasonably priced source for IRF240's? $11.00 each from Newark seems a bit steep....
Thanks for the help!!!!
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin
Old 13th March 2007, 11:33 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: Difference between IRFP240 & IRFP244
Originally posted by Apogee
I'm looking at ordering fets and would like to know what which I should order.
Also, on a side note, does anyone know a reasonably priced source for IRF240's? $11.00 each from Newark seems a bit steep....
Also, I no longer see the "N" versions listed on Newark's site. What's up with that? Are the N's the only versions now available?
fets for what?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th March 2007, 11:36 PM   #3
Apogee's Avatar
Alephs, Zens and whatever else...
I will be ordering IRFP044's for Aleph-X's...
Old 13th March 2007, 11:38 PM   #4
Zen Mod's Avatar
what's with IRFP150N?
Old 14th March 2007, 12:32 AM   #5
gl is offline gl  United States
Steve,
Most people use the 240 instead of the 244. I buy mine at Digikey. The only parts available now are the lead free ones and someone along the supply chain has taken the opportunity to almost double the price to about $4.50 (for 1). A bit of rip really.
Fairchild no longer lists the IRFP240 but shows the FQA19N20C as a sub. It looks like a nice part. Mouser charges $1.92 for 1.
Graeme
Old 14th March 2007, 01:51 AM   #6
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
I'm also very intersted in that which sounds better and who could
answer the question. By the way, Papa still uses 240. But, when
he starts using 244, it might be hmm... sold out tomorrow.
I might have to buy 100 pcs and keep them in the draw.
In case . . ., who knows . . . ^^.
Old 14th March 2007, 02:12 AM   #7
MEGA_amp is offline MEGA_amp
MEGA_amp's Avatar
You can always order direct from International Rectifier, thats the easiest, buy a tube of 25 and chances are they'll be from the same batch, which usually yields better matches.
-john
edit: No stock of Irfp240 at IR, but plenty of the lead free pkg
Old 14th March 2007, 05:23 PM   #8
jupiterjune is offline jupiterjune  United States
Mega Amp John-
Nice tip about IRF--I wish I had known about that last week.....
I think one of the most important criteria listed for selecting mosfets is the input capacitance. IRFP 240's are in the 1200pf range, IRFP 244's, (and 250's) are in the 2400pf range (if I recall the numbers correctly from the datasheets). You get more more high frequency distortion with higher input cap.
TO220 devices, such as the IRFP 634's and 9630's are in the 600pf input capacitance range, but offer about half the power handling. I used the 634's in an A-75 and also in an aleph mini, and they sounded just fine. (bias current in the mini .66 amps for each device).
The TO220's require a number 4 mounting screw if they are to be isolated from the heatsink -- not so easy to tap, so if you are using a lot of output devices, go with the TO247's.
JJ
Old 16th March 2007, 02:53 AM   #9
Apogee's Avatar
Thanks everyone!!!
240's it is...
PS - I'm still looking for a lower cost source for IRF240's if anyone knows of one...
Old 16th March 2007, 06:52 AM   #10
Malotron is offline Malotron  United States
Malotron's Avatar
http://www.tech-diy.com/hexfets.htm
As they are already matched sets you save by only buying what your project requires.
Looks swell on paper...anyone daring to a non IR fet?
-------------------------------------------FQA19N20C IRFP240
gFS Forward Transconductance--------- 10.8 ------------ 6.9
Ciss Input Capacitance------------------- 1080 pF ------ 1300 pF
PD Power Dissipation---------------------- 180 W -------- 150 W
RθJC Thermal Resistance------------------ 0.69 C/W -- 0.83 C/W
-Mal
Difference between IRFP240 & IRFP244Hide this!Advertise here!
IRFP244-PBF Prices MattM Pass Labs 0 3rd January 2007 05:10 AM
IRFP244 ---- Fairchild Vs. IR for Aleph 2? gengis Pass Labs 2 21st May 2005 12:13 AM
Matched IRFP244 Brian Donaldson Swap Meet 46 30th October 2004 08:20 AM
Irfp244 Mano Pass Labs 1 17th January 2002 01:05 PM
Copyright ©1999-2017 diyAudio
