Old 2nd May 2007, 06:34 PM   #81
sinuko is offline sinuko  Italy
In my case YES, William.
Paolo
(less marked but the shape is quite similar).
Old 2nd May 2007, 07:26 PM   #82
Hi William,
I have one photo of my distortion, I hope that you can see samething.
Yes the photo is quite bad.
Xavier,
I tried without McMillan resistor (with 40R to ground), but I foud a residual of distortion (and the time to stabilize the DC off-set is too long) so at the and I decide for 4k74 value.
Paolo
Old 2nd May 2007, 10:43 PM   #83
Originally posted by wuffwaff
are we really talking about the same distortion seen here?
AlephJ-X
This starts at around 22V although the amp only starts clipping at 29V.
William
William,
I would say so, but in my case everything happens at less voltage since my rails are about +/- 17.5v
The latest images I post shows only the remaining of the initial distortion after some changes (Cap, McMillans, etc), but my initial pictures were quite similar to yours. In my case, I got a similar waveform to the one you posted whenever I used bigger caps for B-C of Q3 and Q8 (more than 1nF).
I also detected after removing the McMillan resistors that the behavior was better after the amp had been switched on for a while, having the offset to ground at about -3.5v. If you compare pictures 5 and 6 from my previous post, the only diference is that picture 6 was taken 30 minutes later, with more negative offset to ground.
Paolo,
You are right, removing the McMillans improved things only apparently but did not removed the distortion. It is not the solution, but helps to identify the causes of the problem.
I am not sure yet about it but, could you guys check if you have some improvement in your wave by adjusting the offset to ground to, lets say about -4v instead of near to 0? (only as a test, I am not saying that you leave your amps with this offset as a solution).
Xavier
Old 4th May 2007, 08:33 PM   #84
The one and only
Nelson Pass's Avatar
Originally posted by macka
As I recall the review samples were not biased correctly but the clues are perhaps there.
In that case, the bias current was correct, but the gain of the
Aleph current source was mis-adjusted to less than 50%. Just
shows what happens to review units when the sales
department hijacks them off the test bench.
Old 5th May 2007, 12:33 AM   #85
macka's Avatar
It must have impressed someone on the production line .....LOL
Well that makes all those measurements invalid I guess.
Old 6th May 2007, 07:18 AM   #86
Buzzy is offline Buzzy  Singapore
Wow ! Ur amp looks beautiful. How thick are those wires ?
Old 21st May 2007, 02:03 PM   #87
Stefanoo's Avatar
Xavier...have you figured your problem with distortion on your Aleph X out?
Stefano
Old 21st May 2007, 08:13 PM   #88
Thanks, Buzzy, but I am not sure which wires you are refering too!
Xavier
Old 21st May 2007, 08:23 PM   #89
Hi Stefanoo,
I am quite busy and I haven't much time to test. I just reverted to the previous stable situation to be able to listen music. Anyway the distortion only occurs just before clipping and only for frequencies above 10KHz, so I don't think it is a problem for me for listening music at a normal level.
Xavier
Old 15th March 2011, 02:08 PM   #90
Dmatuszak's Avatar
Beautiful! After being away from the DIY audio hobby for the past 10 years I recently had to repair and tune-up my Pass A75 and have now got the bug again. Out of all the audio gear I've built over the years I think the most enjoyable project was amp building. Anyway you've now got my interest in taking on this project. Can you give me an idea on the cost and where I could get the PCB's, and notes describing the circuit and testing? The A75 was an easy project in the sense everything you needed to know was in the AA article. I'm not sure this is the case here.
Dan
F2 running hot(how hot is hot?) Aron Pass Labs 10 13th February 2009 04:42 PM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 03:34 PM
Aleph-x running, but a little problem oliverniekamp Pass Labs 18 7th May 2006 07:18 PM
Aleph 5 Running (Pic) Jye Pass Labs 5 7th February 2005 08:13 AM
New aleph 5 up and running, have a few ??'s about my measurements. RKC Pass Labs 3 23rd December 2002 05:36 AM
Page generated in 0.13167 seconds (70.13% PHP - 29.87% MySQL) with 11 queries
