Old 22nd April 2007, 05:50 PM   #61
wuffwaff's Avatar
I did some tests too and posted them in my original thread:
http://www.diyaudio.com/forums/showt...47#post1190647
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 22nd April 2007, 08:52 PM   #62
sinuko is offline sinuko  Italy
Dear William,
in my tests I obtain the best results witn 3.3nf between B-C of q3 and q8.
Now I can see a residual of "the strange distortion" just before the clipping.
Paolo
Old 22nd April 2007, 08:54 PM   #63
wuffwaff's Avatar
with 3n3 itīs gone but then the other problem is present (heavy distortion into lower impedances at high frequencies).
William
Old 22nd April 2007, 08:58 PM   #64
Which is a "lower impedances" for you? 6R 4R or lower?
in any case I'll try next week.
Thanks Paolo
Old 23rd April 2007, 08:49 AM   #65
wuffwaff's Avatar
4R and lower. I only test at 8, 4, 2,8 and 2R because thatīs the way my power resitor bank is build.
William
Old 28th April 2007, 04:16 PM   #66
RoboMan is offline RoboMan  Hong Kong
It seems there is no discussion on the situation in posting 39. I think this is a parasitic oscillation (not ringing).
I saw this in my Aleph5 and this can be cured by adding a 1000pF (1nF) cap across the gate resistors of the gain MOSFET and the output, i.e. -out and C of Q4 ; +out and C of Q9 (Grey's version dated 5/24/02).
The waveform is reproduced here:
Old 28th April 2007, 05:54 PM   #67
CheffDeGaar's Avatar
Hi Xavier
Just curious about your generator...
Do you use a CD player with a recorded square wave on a CD ? Your waveform looks like truncated Fourier series attempting to reproduce a square signal, or if you prefer, the Gibbs phenomenon.
If its ringing, it is damped as it begans to decrease until half the high or low levels of your squre wave. But then, why does it begin to re-rise agian after ? The ringing must follow a level change, not precede it Or get a patent on time reversal
If it's oscillations, why are they damped in the middle of the high and low levels ? And why is it so symmetrical ? The duration of a level is an exact multiple of the oscillation frequency. Seem to be too much luck...
Just have a look at the pictures here : http://en.wikipedia.org/wiki/Gibbs_phenomenon
Pretty the same, hu ?
May be I'm completely mistaken, but it strongly reminds me a digital problem... Just tell us where your square signal comes from
Cheers
/Cheff - Falling feels like flying, until you hit the ground
Old 29th April 2007, 03:44 AM   #68
Cheff, you may be right. It was labelled as 1KHz and made me thought it was oscillation. I think it is actually a 10KHz signal (5 X 2 uS per cycle).
Old 29th April 2007, 08:33 AM   #69
You are right, Cheff. The signal is generated by a PC from a wav file and then feeds the preamp. It already has this shape at the input of the AX.
Xavier
Old 1st May 2007, 09:16 AM   #70
macka's Avatar
Hi guys,
This link may help with understanding what is a happening.
http://stereophile.com/solidpoweramp...ss/index4.html
As I recall the review samples were not biased correctly but the clues are perhaps there. In that respect take the absolutes with a grain of salt but there is a trend with lower load impediances. In any case amp reviewed impressively compared to the Halcro on a subjective basis as one would expect.
Note the tests were done at 2 watts.
At 20 kherz the output impediance is relatively higher and given a 4 ohms load this has an effect on the FR response tests particularly at high power levels when doing such test.
With that increase in output impediance I suspect the voltage drop is converted to heat and you get the effect you have been discussing. I doubt if this is an issue in normal operation.
This is only my educated theory and I hope it facilitates some productive discussions.
best
Ian
F2 running hot(how hot is hot?) Aron Pass Labs 10 13th February 2009 03:42 PM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
Aleph-x running, but a little problem oliverniekamp Pass Labs 18 7th May 2006 06:18 PM
Aleph 5 Running (Pic) Jye Pass Labs 5 7th February 2005 07:13 AM
New aleph 5 up and running, have a few ??'s about my measurements. RKC Pass Labs 3 23rd December 2002 04:36 AM
Page generated in 0.11344 seconds (80.28% PHP - 19.72% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
