Old 15th March 2007, 02:38 PM   #21
What type of tube amplifier are you comparing it to?
My tube amplifier is a 4 KT88 PP per channel in triode mode
Does the absolute DC offset stay fairly steady at 350mV? or does it drift slightly?
When I connect the amplifier I have around 4v of absolute DC offset that goes down quickly to less than 1v and then needs one hour to go downto around 350mV. It stays between 340 and 360mV.
However, these numbers are only for the second channel. The first channel I did was not as good. The DC offset between outputs is about 60mV and the absolute DC offset about 900mV. I plan to change the input differential fets for this channel. In fact, for the second channel, I used a socket so I could try some of them in real conditions. I will definately do the same for the first channel.
can you notice any hum at your speakers? I am going through final tweaks on my pair and have a faint hum at the speaker still, however I still plan to eliminate it completely (and post some pictures) when I get some free time. It is definatley a slow process
I only notice some hum at the speakers if I am closer than 2 meters. The ripple I measured was about 80mV.
I am also in the process of fine tunning the amps, but I want to stay some weeks just listening music and enjoying the amp. Then I'll start the tweaks.
I agree with you it is a slow process, but it pays when you just have finish the amp and you enjoy it with your favourite music drinking your favourite red wine!
Xavier
Old 15th March 2007, 04:47 PM   #22
Stefanoo's Avatar
Originally posted by Stefanoo
Hi!
i noticed that you used mills resistors...isn't it?
Another thing.....on your picture i can see just a part of your loudspeakers...are your speakers B&W?! they really look like!
I don't know if oyu gave the necessary time to the amp to burn in all the new components.....how does it sound like so far?
What stereo parts do you have?...cables...source....speakers....?
Best,
Stefano.
Still waiting to know the things quoted above ...
Stefano
Old 15th March 2007, 05:26 PM   #23
Hi Stefanoo,
I forgot to answer your questions in the first page. Sorry about that!
Yes. The source resistors and output resistors are Mills. The rest are Dale CMF-55-143.
You are right. They are B&W Nautilus 803. Although they are marked as 8 Ohms, their minimum impedance is 3 Ohms. That is the reason for having quite high bias (7.2A per channel).
Not yet, but I don't expect too many changes in the quality of the sound. In fact one of the channels was up two weeks before the other and they sound the same.
Speakers: B&W 803
Amplifier Aleph X
Preamp Aleph P1.7
CD Rotel rcd991 modded
Phono preamp Aleph Pearl (with MC pre and differential output)
Turntable Michel Syncro + cartridge Shelter 901
Ciao,
Xavier
Old 15th March 2007, 06:36 PM   #24
Netlist is offline Netlist  Belgium
Netlist's Avatar
Split thread can be found
here.
/Hugo
Old 28th March 2007, 11:12 AM   #25
After some days of listening, I did some fine tunning to the amps:
1- I reduced the relative DC offset of both channels by changing the differential pairs (I have sockets on both channels). Now I have 7 mV in one channel and 25mV in the other.
2- I noticed that when puting the cover to the enclosure, there is an increase of the temperature that produces changes. The absolute offset increased about 1v so I had to re-adjust V2 through the holes of the cover, without removing it.
The cover was also reducing the bias. I had to re-adjust V1 and V3. Doing so through the cover was quite easy. Measuring the voltage at the source resistors was more difficult. I had to remove the cover and measure each resistor immediately since once the cover was removed, the voltage drifted very quickly. Any alternative ideas on how to measure the bias of each side of the channel without removing the cover would be appreciated!
3- In order to reduce the remaining hum, I added two capacitors in parallel (1000 + 10000 uF) right at the mosfets for each side, i.e. a total of 22000 per channel (see the picture). Each pair is connected to the drain of the current source (V+) and the source resistor of the output devices (V-) for each side of the monoblock.
This totally removed the remaining hum in the left channel while for the right channel, you have to put your ear almost against the speaker to hear some noise.
Xavier
Old 31st March 2007, 10:07 AM   #26
I did some measurements for 8R and 4R loads.
The measured peak voltage before clipping was 32v (22,6v RMS) for 8R and 28v (19,8v RMS) for 4R. I measured +17,54 and -17,58 from psu and bias about 7.2A
The voltage before clipping for 4R is a little bit less than expected for 4R (98W instead of the 105W according to the excel sheet). I tried to increase the bias to see where was the limitation but I was having 28v consistently, so probably the voltage loss at the fets and the source resistor is higher than expected.
Clipping at 1KHz and Z=8R
Old 31st March 2007, 10:12 AM   #27
Clipping at 1KHz and Z=4R
Old 31st March 2007, 10:17 AM   #28
Now without clipping
Old 31st March 2007, 11:52 AM   #29
sinuko is offline sinuko  Italy
Dear Xavier,
thanks for your data.
Can you check if the sine wave at 10kHz (or hihger is better) is correct just before the clipping?(On my Aleph-x (I hope to post it in the next fews weeks), I notice same strange shape (not clipping) at high frequency before the clipping (3-4V).).
My power supply is -21 + 21, and I notice this "strange" shape at 22Vrms output (on 8R).
Thanks Paolo
Old 31st March 2007, 12:11 PM   #30
Paolo,
I tried with 20KHz and I have exactly the same thing.
First picture, the signal is still OK:
F2 running hot(how hot is hot?) Aron Pass Labs 10 13th February 2009 04:42 PM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 03:34 PM
Aleph-x running, but a little problem oliverniekamp Pass Labs 18 7th May 2006 07:18 PM
Aleph 5 Running (Pic) Jye Pass Labs 5 7th February 2005 08:13 AM
New aleph 5 up and running, have a few ??'s about my measurements. RKC Pass Labs 3 23rd December 2002 05:36 AM
Page generated in 0.11477 seconds (84.50% PHP - 15.50% MySQL) with 11 queries
