#11 |
Paper mache horn fabricator
Beautiful, clean job, Xavier. Clever approach.
John
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#12 |
nice idea with those connectors. Soon well be debating the sound of various plastic connectors
Heatsinks are really nice too, where are they from? |
#13 |
Great amp,
Can you give some spec's on the heatsinks. Dimensions, thermal coefficient etc. Thanks, Adrian |
#14 |
Very nice job, Xavier! What's about pcb?
#15 |
Bravo Xavier.
with 18 V rail voltage Which is the maximum voltage swing at +- ouput connector on your aleph-x before (voltage) clipping? Wichi value of McMillian resistor have you use?(4.7k?) Thanks Paolo x Beppe: about the pcb http://www.diyaudio.com/wiki/index.p...-X+Compact+PCB Ciao Paolo |
#16 |
i didn't know there could be all this "compaesani" on this DIY forum!
NICE! Ciao, Stefano.
Stefano |
#17 | ||
Mmmmm.... the GB was 2 years old ![]() Quote:
How do not love them?! Nice to meet on this forum |
#18 |
Thank you guys! And, specially thanks to Grey and Nelson. It is a great design!
Let me try to answer some of your comments and give some more details: The heatsinks are Fischer SK157 0,22șC/W. Their size is 300x200x83mm. The PCBs come from Carondimonio. Sinosuko is right, that link points the GB that I joined quite late. Regarding the psu, I am using one transformer Amplimo 2x15v 625VA for each channel. CRC for filtering, using 4 100mF capacitors, i.e. a total of 400mF per channel. I am using 8 IRFP044 per channel and the value for the source resistors is 0.27R (yes, they are Mills). The McMillan resistors are 4.75k, R1/R45 68R and I am not using caps at the input. Regarding clipping, this measurement is still pending. However, I would say that the voltage at the fets is not as high as 18v, is more between 17.6 and 17.7v. My initial impression on the sound is very positive. The sound is really good. Bass is tight and controlled, the midrange is sweet and extremely transparent. The highs are a little brighter than my tube amplifier but less than commercial transistor amplifiers. Xavier |
#19 | |
#20 |
Great work! It is good to see more people complete the Aleph-x sucessfully
What type of tube amplifier are you comparing it to? Does the absolute DC offset stay fairly steady at 350mV? or does it drift slightly? Also, can you notice any hum at your speakers? I am going through final tweaks on my pair and have a faint hum at the speaker still, however I still plan to eliminate it completely (and post some pictures) when I get some free time. It is definatley a slow process Jeff |
| F2 running hot(how hot is hot?) | Aron | Pass Labs | 10 | 13th February 2009 04:42 PM |
| What advantages running ported midbass if you are running a sub? | mitchyz250f | Multi-Way | 3 | 20th May 2008 03:34 PM |
| Aleph-x running, but a little problem | oliverniekamp | Pass Labs | 18 | 7th May 2006 07:18 PM |
| Aleph 5 Running (Pic) | Jye | Pass Labs | 5 | 7th February 2005 08:13 AM |
| New aleph 5 up and running, have a few ??'s about my measurements. | RKC | Pass Labs | 3 | 23rd December 2002 05:36 AM |
| Page generated in 0.10592 seconds (77.93% PHP - 22.07% MySQL) with 11 queries |
