H Type Balanced Attenuator.
Old 22nd March 2007, 09:39 AM   #21
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Hi David,
this would work. The only problem (for me) would be the programming of the PIC.
GeeVee,
why are you confused? The series resistors are easily within 1% wich is a lot better than any pot I know of and in dB a very small error.
If in option A the pots are not exaxtly the same you will also have a difference. This will be bigger than in the balanced version (have a look at the Borbely website for an explanation).
Where the wiper is connected is not important. The pot is connected as a variable resistor between the +out and -out.
The Dantimax volume controls can not be used for option B, only for option A . What could work is if you use the ladder option (24 step) with different resistors.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 16th July 2008, 01:48 PM   #22
Berry is offline Berry  Netherlands
Default unbalanced preamp
I would like to convert the unbalanced signal from my preamp to an balanced one. What is the best schematic ?, are there better ones ? It is for the Aleph 5
Old 16th July 2008, 05:39 PM   #23
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Default Re: unbalanced preamp
You actually might like to consider building the BOSOZ preamp. It's an easy circuit and handles balanced/unbalanced conversions very nicely. There are also less components in the signal path.
The level of effort would be roughly comparable. With a little more work there are the other BOSOZ variants with X topology and CCS.
-David
Old 16th July 2008, 08:05 PM   #24
juma is offline juma  Germany
juma's Avatar
If you want to do it with OpAmps and DiffAmps here is the one that I used few times. This one might not be the best, but it won't be easy to find a better sounding one.
First chip is just a buffer and there's a plethora of good circuits to choose from, though it should be capable of driving a low Z input of diff. amp - OPA1632 - here you can also use the THS4131 (same pinout as OPA1632) or any discreet circuit you like - you'll find a lot of them on this forum.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 17th July 2008, 06:39 PM   #25
I started a new thread, balanced/unbalanced preamplifier. In the zip file there are three schematics, are those better ?
http://www.diyaudio.com/forums/showt...hreadid=126529
H Type Balanced Attenuator.Hide this!Advertise here!
Looking for Balanced attenuator ideas cartman Analog Line Level 11 30th May 2008 02:11 PM
WTB: Balanced attenuator and switch folkeb Swap Meet 0 25th May 2006 04:33 PM
Which attenuator type for xBosoz and Aleph30 hifimaker Pass Labs 3 29th March 2006 04:16 PM
attenuator balanced 600/600 alexidoia Parts 2 13th February 2006 08:38 PM
BOSOZ Balanced Attenuator Set-up hifimaker Pass Labs 5 2nd February 2005 03:25 AM
