Old 13th March 2007, 07:09 PM   #11
wuffwaff's Avatar
I don´t want to confuse you but here´s another method:
1. Set the output to something like a 5-10V sinus (8 or 4 ohms)
2. Measure the voltage over each current source fet´s source resistors
3. add all of the voltages and devide by the source resistor value. Now you´ve got the current from the current source
4. measure the voltage over the output resistors and devide by their combined value. Now you´ve got the total output current
5. Devide the C.S. current by the total current et voilà the AC-Current-Gain
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 1st June 2007, 11:48 AM   #12
Jaac is offline Jaac  Netherlands
Jaac's Avatar
Oke did some testing yesterday with the R21. The AC current gain is set properly. The dc bias is almost 2 amps total. With +/- 40V rail i could pull out something about 23,5 Vrms into 8 ohm thus 69 Watt with THD+N under 0,1%.
I also completed the other channel ! But I measured some 50/100 Hz noise from the mains i think on the output.
We have checked the powersupplyconnections with a old tek scope with differential input at the connection between the rectifier diodes and the big caps and measured those nice diode currents voltage drops over these connections. I'll check these next week after i connected these amps to my system !!!
Thanks Nelson and Jaap Pees ( for his test bench and knowledge ) and the others for pointing me in the right direction. Will email you my project for the diypass website soon.
gr Jaac
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 2nd June 2007, 02:29 AM   #13
The one and only
Nelson Pass's Avatar
Nothing more gratifying than progress.
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
high frequency distortion paul_peraic Parts 2 7th May 2008 03:48 PM
Turntable High Frequency Distortion Sibilance Signal Analogue Source 1 8th January 2008 06:09 PM
Low Distortion High Dynamic Range Pre-amp Nico Ras Pass Labs 64 18th May 2007 05:26 AM
Is there a no/gain preamplifier schematic using high-distortion EC90? Layberinthius Tubes / Valves 6 10th May 2004 06:13 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
