Jfet Bosoz? - Page 3 - diyAudio
Old 11th March 2007, 07:16 PM   #21
The one and only
Nelson Pass's Avatar
Originally posted by dw8083
If this Jfet BOSOZ was connected only to an Aleph30, are the output coupling caps necessary? It would be great to eliminate them if possible.
The + input is direct coupled, and usually the - input has a
capacitor to give low offset. I would keep the coupling caps,
but you could then eliminate the cap on the A30
Old 11th March 2007, 09:05 PM   #22
with output followers
if you want to "gild the lily"
Were you thinking of something like seven watt output followers?
Old 11th March 2007, 09:33 PM   #23
The one and only
I believe that would qualify.
Old 13th March 2007, 08:24 PM   #24
hifimaker's Avatar
Here's a first start at a design. Any thoughts? I'd like to get some feedback before building it. Source followers could be added.
-David
Old 13th March 2007, 08:35 PM   #25
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
-David
increase current (change J type,or use two or use another type of CCS);
after that -be careful with dissipation; decrease PS voltage ,if needed
edit:
R7 and R8 are in 10x magnitude bigger for my liking.........susy effect is smaller with them,degeneration is greater.........
for vinyl (next post,edit after):
Q2 and cousin are CCSes,cascodes,what you like?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 13th March 2007, 08:40 PM   #26
Onvinyl's Avatar
OK folks,
I'll be the fool of the day and the one who asks the question that no one dares to ask...
What is the function of Q2 and how does it work?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 13th March 2007, 09:12 PM   #27
hifimaker's Avatar
Thanks Choky for the insight.
This version has a second J511, lower voltage, and adjustments to R5-8. I would appreciate help in verifying the design and specifically in selecting values for R5-8. I think the values maybe a bit low.
Thank you,
-David
Old 13th March 2007, 09:24 PM   #28
Zen Mod's Avatar
Thank you,
-David
try like this
you must adjust R5 and R6 to catch J511's 4,7mA through each side
connection of J511 corrected and few other things
but,I usually make a mess............
edit:
move both 100K resistors to 2k2/22k node (not before 2k2 but after,ditto on gate)
Old 13th March 2007, 09:42 PM   #29
hifimaker's Avatar
Thanks Choky, I missed the wire between R7 & R8, it's now added. I'm still wondering if R5 & R6 are on the small side?
Here's the updated schematic.
-David
EDIT: Moved C1 & C2 back, outside of R2 & R4
Old 13th March 2007, 09:59 PM   #30
Zen Mod's Avatar
-David
if your intention was to make CCS-es with two upper LSKs (hehehe) ,then you must look in data or test them ..........I don't know from top of my head what's Ugs for 4,7mA.............off course-you must match them,so you'll know then what resistors to choose
besides that-for later -you can add followers on output,naturally with overall feedback connected all around
edit:
if you are lazy for testing and matching,you can always send me handful of little critters and I'll do that for ya
Krazy JFET-cascoded Pass BOSOZ jh6you Pass Labs 60 17th March 2006 12:19 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
Krazy PSU for JFET cascode BOSOZ jh6you Pass Labs 24 14th February 2006 03:00 PM
Cascoded jfet in X-BOSOZ?? Magura Pass Labs 44 31st January 2006 08:00 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
Copyright ©1999-2017 diyAudio
