yet another newbie Zv9 forums
Old 7th March 2007, 11:15 PM   #1
Ronnal is offline Ronnal  Norway
Send a message via MSN to Ronnal
Default yet another newbie Zv9 forums
Hi all,
Allmost fininshed my Zv9 based on Veterans excellent boards.
Its my first amp, so I have a silly question.
1 Can I use 25V caps for C2, 3, 4, 5, 6 & 9 ?
2 Can I use inrush limiter thermistor (2,5ohm 7A) on primary side of transformer
3 Do I need some resistor or cap between star point ground and audio ground ?
4 before you ask, I did search the forum, and found answers for my many other questions. Except for many answers given by Stenoe and Veteran. Thanks guys
Wish me luck
Old 8th March 2007, 12:08 AM   #2
neil_kaye is offline neil_kaye  United States
neil_kaye's Avatar
Hi Ronnal,
I can't offer any answers to question 1 but for the others, and this is based on my recently completed V9:
2. Thermistor: i used a 3A 10ohm resistor on live between the switch and toroid. I read somewhere that the inrush current on a V9 is low so a thermistor is not required. I have had issues with popping in the past so i thought it would not hurt. Either way may sure you use a slow blow fuse.
3. Do you mean between the star ground and the ac ground? I did but i have in the past. Do not wire the two to the same point. In the past i used a 10ohm resistor between the star ground and the chassis the prevent any ground noise getting back in the circuit from the AC side.
Check out this link for the wiring diagram... tried and tested:
http://www.diyaudio.com/forums/attac...amp=1168227029
http://www.diyaudio.com/forums/showt...8&pagenumber=3
good luck
Old 8th March 2007, 08:38 AM   #3
Thanks Neil,
Yeah I saw that thread and loved it. Especially liked the visual viring diagrams, but didnt notice the values inserted
So if I understand correctly: separate star ground for each channel. Separate star ground from AC ground with thermistor, do not wire the stargrounds and AC ground to the same point..
Ok thanks.
Would you mind trying to measure the voltage that C6 and C3 sees ?
Ronald
Old 8th March 2007, 08:49 PM   #4
thomaseliot is offline thomaseliot  Europe
I would go with values in this BOM:
http://www.diyaudio.com/forums/showt...0&pagenumber=1
Old 13th March 2007, 09:43 AM   #5
Thanks guys, You have been of great help.
New parts ordered and hopefully compleete amp can be posted in a couple of weeks - ending this nearly 1 year long quest
Perhaps starting a new quest...
Ronald
yet another newbie Zv9 forumsHide this!Advertise here!
New to the forums.. XXLPeanut Introductions 3 24th February 2013 06:14 PM
New to these forums 2litre Introductions 3 22nd July 2005 10:57 PM
New forums! Jason Everything Else 11 14th December 2001 03:15 AM
