Can I parrallel the outputs of a BOSOZ pre-amp?
Would the two channels sum together? |
#2 |
yes you could. The current capability would double but the output voltage would stay the same. Why do you want to do that? William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#3 |
I knew someone would want to know....
I use the BOSOZ as buffers in a line level passive crossover driving a bi-amped system... I've been thinking about experimenting with some full range speakers, which of course would not be bi-amped, so I would just parrallel the high and low channels of the passive line level crossover together at the output of the BOSOZ and feed a single ampliphier channel with the summed signal. Since the BOSOZ has gain controls for each channel, I could vary the gain of the high and low channels and have a sort of tone control for the full range speaker. hope it works... |
#4 |
I maybe don't understand the question but, I think the two outputs would sum together to be 0V (ideally).
Buffers??? |
#5 |
Audionut,
if you use different input signals I´m not shure it will work. Why don´t you leave the crossover out with full range speakers? William
#6 |
I could just take out the filter...but I liked the idea of "tone" controls.
In the bi-amped system, I can vary the high and low channels to suit whats playing... |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Bosoz | lawbadman | Pass Labs | 5 | 14th July 2003 02:10 AM |
| 10K Pot for the BOSOZ | raincheck | Pass Labs | 13 | 20th September 2002 06:22 PM |
| Page generated in 0.08358 seconds (74.94% PHP - 25.06% MySQL) with 10 queries |
