Old 4th June 2007, 12:16 AM   #641
Would two BOSOZ's in series drive the F4 enough to power regular speakers as well as say, Aleph 30's
Old 4th June 2007, 04:13 PM   #642
How about using a couple of LM3875 as preamp? With one of them inverting it should be possible to run the F4 balanced. Maybe...
Iwahn
Old 4th June 2007, 05:21 PM   #643
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Iwahn
that can't be on par with F4
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 4th June 2007, 05:26 PM   #644
Russ White's Avatar
Send a message via Yahoo to Russ White
Much better would be the LME49810... Just tie sink and source.
Less pulp more juice Twisted Pear Audio.
Old 15th June 2007, 07:42 AM   #645
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Nelson,
Since the F4 seems to exist , how about an actual photo of it?
Old 15th June 2007, 01:00 PM   #646
I thought all the First Watt product used the same chassis...assuming that the gears of my cognition have not stripped (no guarantees), it'll look the same as the other fellas.
Grey
Old 15th June 2007, 03:44 PM   #647
diyAudio Editor
Variac's Avatar
I specifically asked because this one seems to need a LOT of heatsink- more than most of the previous amps I think? Members seem to be happiest with heatsinks that are almost 30x30 by 50 cm per channel I believe and that's a lot bigger than the typical First Watt chassis I think.
If in fact Nelson uses the same heatsinks as before, with their horizontal orientation, it shows that the requirements are not quite as onerous as implied..
PLus the face plate will look different....
Old 15th June 2007, 04:49 PM   #648
steenoe is offline steenoe  Denmark
steenoe's Avatar
As far as I recall the F4 actually dissipates a bit less than the usual SE/CCS amps from NP. Approx 80 watts per channel.
Usually this figure is 100 watts.
Steen
Old 15th June 2007, 04:50 PM   #649
Jaac is offline Jaac  Netherlands
Jaac's Avatar
Let's say 2 amps bias per SE channel bij 44 volt is 88 Watt in class A to dissipate in a heatsink. So lets see the specs for thermal resistance of a irfp240
Tj-c =0,83K/W, Tc-s = 0.24K/W 0,5 K/W for an isolation plate and lets put al six on one 0,3 K/W heatsink (200mm SK56 from fisher).
Thats 1,8K/W best for a single FET. Gives me a total of 3.37K/W from junction to ambient.
One FET dissipates 88/6 Watt multiplie that by the 3,37K/W gives 49,4 K above ambient for the junction temp.
I think or was it to quick and simple ??
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 15th June 2007, 05:45 PM   #650
diyAudio Editor
Variac's Avatar
That fiendish Nelson seems to design his projects to fit the case!
Actually I'll bet he figured that first Watt will probably never exceed 25w/ch class A and ordered the case from there..
Ok OK - I guess I now know what it will look like....
Best advice on the heatsinks was "Crank up the bias until its at max allowable temp" Then I guess you can measure the bias and decide if that's enough. There never seems to be "too much"
If not enough: mas heatsink.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
