Old 8th May 2007, 05:18 PM   #551
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default Re: Re: Matched
Originally posted by massimo
NO, they cannot.
Think about the P.S.: it's dual, it has a + and - rail. Thus you need N channel and P channel devices. It's mandatory for a push-pull circuit!
The only reason i asked is because my old N-Channel amplifier used the same configuration EXCEPT i used all IRFP240's and it worked 100% fine, i just wanted to make sure before i ordered them
Thank's for the help.
Jase
Old 8th May 2007, 05:22 PM   #552
Banned
Just so people know or if wondering where to get matched sets of Fet's I am ordering mine from, this person.
http://tech-diy.com/hexfets.htm
Old 8th May 2007, 05:28 PM   #553
massimo is offline massimo  Italy
You can use an NPN + PNP circuit up to the driver section and then two NPN output devices. This tecnique, knonwn as "quasi-complementary" was used in the past when PNP power devices weren't available.
A great design using a similar circuit was the original version of the British Cyrus integrated amp (very good sound for that time),
but the F4 is different and I don't think you can drop directly in N channel only power mosfets.
Old 8th May 2007, 05:48 PM   #554
Banned
Thank you for clarifying that for me, learn something new every day.
Old 8th May 2007, 08:03 PM   #555
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
The Phase Linear is of course a totally different amp but since this schematic was easily available I pass it on as an example of a quasi-comp circuit so you have an idea.
http://members.aol.com/phasetek2/pl14.jpg
The mosfet citation is another, better example.
http://www.passdiy.com/pdf/citation.pdf
/Hugo
Old 8th May 2007, 08:10 PM   #556
Banned
/Hugo
I used to have one of these, actually still miss it was a great powe-ramp, had some mods done to it too, Could sit in front of that led display for hours and watch it bounce around.
Old 8th May 2007, 09:58 PM   #557
Banned
F4 transformers,
Ive looked on ebay and have found a perfect pair of Antek transformers 400va @ 18-0-18 witch gives 18 * 1.4 = 25.2V dc for rails Is this to high for the F4 ? Im planning to use 2 transformers one per channel.
Jase
Old 8th May 2007, 10:02 PM   #558
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by jleaman
F4 transformers,
Jase
when you saw last time Papa's amp,where is 1,41 adequate factor ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 8th May 2007, 10:05 PM   #559
18-0-18 V looks good and is the same value indicated by the Master the F4 schematics.
18 * 1.4 = 25.2 is purely theorical. Very often you get 1-2 V less.
If you get an higher voltage, you can always use a CRC or (better) a CLC filter to lower the voltage and the P.S. noise.
Old 8th May 2007, 10:14 PM   #560
Banned
I definatly agree, i just connected my fluke meter back from calibration and i checked our AC wall voltage of 122, then looked at my Alephs that i have now,
Inside is a 300Va with 16V secondary with calculations it should have rail voltages of
16 * 1.4 = 22.4V rails BUT when measuring them i see 20.1V so the voltage is a little dropped i guess.
So i think ill be ordering 2 of these 18-0-18's and use that.
Thanks for your help massimo.
Jase
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
